Page 2 of 3 1 2 3
Re: 440 has no signs of life....will not fire at all [Re: stumpy] #647491
03/22/10 11:42 AM
03/22/10 11:42 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Make sure your plug wires are on correctly. Maybe the wires are off by one on the cap and that's why you can see spark but not when its the right time to fire that cylinder.
Maybe your Carburetor is gummed up? How long was it sitting before you swapped it on to this motor? Are the bowls filling up? Can you smell fuel?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 440 has no signs of life....will not fire at all [Re: 451Mopar] #647492
03/22/10 12:39 PM
03/22/10 12:39 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My E-Mail got bounced back, so I sent you a private message here.
Re: 440 has no signs of life....will not fire at all [Re: 451Mopar] #647493
03/22/10 02:47 PM
03/22/10 02:47 PM
No backfires, no sputtering, nothing.
Even with the distributor "off" or wired clockwise you'll occasionally get a spark that "hits" on a cylinder.
It's got to be an ignition problem!
Re: 440 has no signs of life....will not fire at all #647494
03/22/10 11:31 PM
03/22/10 11:31 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
So here is where I am. I pulled all wires, put number 1 at TDC on compression stroke. Relaced it all up..primed carb with gas. I get some popping out the exhaust and through carb, some smoke drifting out of carb...but no signs of firing off? Please tell me I did not hose up the timing chain install! I lined up cam and timing mark. Used a standard NAPA brand timing set. I have good spark, plugs are good, wires are good..the shortblock I built had piston, rings, crank..basic shortblock already assembled. What gives? Compression feels strong. I will get a compression tester tomorrow to double check it. This is very frustrating.... gotta be something I am missing here..
Re: 440 has no signs of life....will not fire at all [Re: dssaa] #647495
03/22/10 11:38 PM
03/22/10 11:38 PM
1 Did you wire the distributor COUNTER-CLOCKWISE?
2 Are you for sure using a BB distributor?
Lining up the dots when doing a timing chain doesn't get it! You really should degree in the cam. My MP .528 Mechanical and Cloyes Tru-roller combo was 8* retarded when installed in the "straight up" position!
Re: 440 has no signs of life....will not fire at all [Re: dssaa] #647496
03/22/10 11:45 PM
03/22/10 11:45 PM
When you put the marks on TDC how did you line up the reluctor/magnet & was the rotor under (or very close to) the #1 wire cap terminal. Yes it's gotta be something simple we have missed
Re: 440 has no signs of life....will not fire at all [Re: RapidRobert] #647497
03/23/10 12:03 AM
03/23/10 12:03 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Yep, its the same distributor that I was running on the old motor (440). I lined it up, number 1 to firing point on rotor... I have double checked every wire..this is driving me nuts!
Re: 440 has no signs of life....will not fire at all [Re: dssaa] #647498
03/23/10 12:42 AM
03/23/10 12:42 AM
Electronic distributor?
What's your reluctor gap?
Should be .008-.011 IIRC with a brass feeler gauge.
Re: 440 has no signs of life....will not fire at all [Re: dssaa] #647499
03/23/10 12:54 AM
03/23/10 12:54 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
make it easy !
remove the dist from engine and keep it pluged to the wire harness !
turn on key
spin dist shaft to verify you are getting spark !
you should easily hear spark current making a sharp ticking sound .
no spark , go back and clean grounds and try agin !
Re: 440 has no signs of life....will not fire at all [Re: dssaa] #647500
03/23/10 01:28 AM
03/23/10 01:28 AM
Ca
speedy515 Offline
speedy515  Offline
Ca
I don't claim to be an expert on neutral safety switches..in fact...I don't really now squat about them. When you turn the engine over, doesn't the neutral safety preclude the plugs from firing? If mine fire in sequence, that would indicate the ability for the motor to ignite the fuel? So, as a dummy..where does the neutral safety switch prevent the ignition system from functioning? Yeah, off topic, but still a good subject to learn from... and I am out of gas in my spare can cuz the kids put it in the four wheelers today
The neutral safety switch prevents the starter from turning over the engine. If the engine turns over the switch is engaged.
Re: 440 has no signs of life....will not fire at all [Re: dssaa] #647501
03/23/10 07:20 AM
03/23/10 07:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm guessing you tried moving the distrib around some? sounds like you are getting fire and gas it's just not in "time" yet.
Coming soon!!!!
Re: 440 has no signs of life....will not fire at all [Re: Mr.Yuck] #647502
03/23/10 07:45 AM
03/23/10 07:45 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
With all the messing around you have done the cylinders are very likely gas washed, the cam lube off the cam, and the oil full of gas.
Re: 440 has no signs of life....will not fire at all [Re: MoparforLife] #647503
03/23/10 11:53 AM
03/23/10 11:53 AM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
Hope this isn't the case, but a long time ago I put an OHC Datsun engine together and had the cam timing off. It sorta fired and would not start. Unfortunately in my case all of the valves got bent because things were in the wrong place at the wrong time.
Get out your compression tester. If you have little or no or wildly varying readings, you could have some bent valves at this point.
Hope it is something more simple though.
Re: 440 has no signs of life....will not fire at all [Re: HitIt] #647504
03/23/10 12:20 PM
03/23/10 12:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Mopar V8s are not interference motors like the Jap scrap. They won't bend valves if the timing chain is off.
Re: 440 has no signs of life....will not fire at all [Re: stumpy] #647505
03/23/10 12:39 PM
03/23/10 12:39 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
the problem is simply this..your old cars distributor wasnt set up from #1 at tdc it was setup willy nilly..you need to pull all the wires off it line it up on #1 [compression stroke] and rewire the cap correctly for this motor.. good luck it may be too late for this motor however... dan
Re: 440 has no signs of life....will not fire at all [Re: stumpy] #647506
03/23/10 12:43 PM
03/23/10 12:43 PM
Upper Midwest
Upper Midwest
Oh yes they will. Seen lots of eye brows when timing chains went south.
Re: 440 has no signs of life....will not fire at all [Re: MoparforLife] #647507
03/23/10 02:10 PM
03/23/10 02:10 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Just for the heck of it change out the ballast resistor. Seen them in the past give some problems with starting. Also check the electronic pickup in the distributor. Just a suggestion.
Re: 440 has no signs of life....will not fire at all [Re: MoparforLife] #647508
03/23/10 02:13 PM
03/23/10 02:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I haven't seen a factory motor do it but yes if you have a built engine it's very possible.
Re: 440 has no signs of life....will not fire at all [Re: stumpy] #647509
03/23/10 02:20 PM
03/23/10 02:20 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
a stock rebuild would not have any interference issues. He needs to get a buddy over and help him out. It's hard to do all that junk by yourself.
Re: 440 has no signs of life....will not fire at all [Re: Mr.Yuck] #647510
03/23/10 02:23 PM
03/23/10 02:23 PM
Upper Midwest
Upper Midwest
I sure have seen a lot of mopars that had eye brows when the timing chains took a crap. Go figure. everything can look good on paper.
Page 2 of 3 1 2 3
