Page 1 of 3 1 2 3
Oil Drinking?? #64693
05/27/08 06:03 PM
05/27/08 06:03 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
I believe a while back, I posted how my 6,000 mile 318, stock rebuilt heads, stock replacement pistons, and Comp XE268 cam was using some oil. As of late, it seems to be using a quart every 750 miles. I am using 10w40 with Comp Cams lube. Oil presure is good, the motor runs great, with plenty of power and the only smoke is when I am going down a grade on a freeway when I back off the throttle, or if I open up the secondaries. Even that is only a white/very very light blue (if at all). It will not do anything upon start up. There were no valve seal remnants under the valve covers and the oil looks great. the plugs were not black, but some were ever so slightly gray, maybe a bit of ash.
I will add that in those 750 miles, it is turning 3,000 rpm on the freeway 50% of the time.
About a two months, or 1,400 miles ago,I installed a Holley 650 DP on the motor. It seems since then, I have noticed the consumption. Maybe it is a coincidence. What I do know is that the power brakes and the PCV hose share the rear vacuum port on the back of the carb. Could the brakes be using more of the vaccuum and leaving little for the PCV to operate, thus causing my slight issue?
Or am I overlooking or overreacting to this consumption? Maybe I am looking in the wrong direction, as to me, this seems like a minor problem. Advice or comments are appreciated.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Oil Drinking?? [Re: MoparJ] #64694
05/27/08 07:11 PM
05/27/08 07:11 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
Cmon gentleman....
I need some opinions, 318 or not...lol...
Re: Oil Drinking?? [Re: MoparJ] #64695
05/27/08 07:31 PM
05/27/08 07:31 PM
God's Country Maryland
GODSCOUNTRY340 Offline
If you're sure it's not leaking past the valve guides or valve seals it could be the intake gasket not sealing at the bottom. These will leak just enough at high vacuum to cause your problem. To eliminate the PCV as a problem just unhook it and block the port. Make sure the valve cover has a baffle under the PCV valve. One other culprit could be the piston rings failed to seat. When you first started the new engine was there any kind of carb problem that may have washed the rings?
Re: Oil Drinking?? [Re: MoparJ] #64696
05/27/08 07:44 PM
05/27/08 07:44 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
I thought the brakes went to the manifold and the PCV to the carb...
Re: Oil Drinking?? [Re: MoparJ] #64697
05/27/08 08:41 PM
05/27/08 08:41 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
What type of oil are you using? Conventional or Synthetic? The reason I ask is conventional oil has an inherent characteristic of being volatile. Meaning at normal operating temperatures, some components of the oil burn off or evaporate. Synthetic oil is resistant to this type of evaporation loss. Although, one quart of oil in 750 miles seems a bit excessive for evaporative loss. Regardless, it could be plying a roll in your oil loss issue. What does the oil look like? Such evaporative loss also increase the oils viscosity. What is the engines operating temperature? Is it higher than normal? Does the engine ever overheat?
Just a couple other possibilities to consider.
Re: Oil Drinking?? [Re: MoparJ] #64698
05/27/08 09:19 PM
05/27/08 09:19 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Sounds like valve seals. Is there smoke at start up too?
Re: Oil Drinking?? [Re: CompSyn] #64699
05/27/08 09:20 PM
05/27/08 09:20 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
This motor never overheats. It stays right at 180 all of the time and rises to 195 in only the warmest of days. The oil looks great, not too thick. It is 10w40 Castrol with a bottle of Comp Cams lube. Maybe the lube is doing more harm than good at this point?
I didnt really wash out the rings at break in. Initially, there was some difficulty to get it started as the oil pump/dist gear was not set in correctly, but I didnt pump a bunch of fuel into it. As soon as I righted that issue, it fired right up and I broke it is for 30 minutes at 2,000-2,500 rpm, stopped to change the oil, then ran it some more.
I would anticipate worse running, misfiring, and more smoking if it were the rings, wouldnt you all agree? It has run great for 6,000 miles.
I wouldnt think the carb is pumping too much fuel in, even though it is large for a stock 318 (650 DP electric choke with #70 jets. I do not smell fuel in the oil. Should I back this back down to the Eddie 600 I have? It its fairly rich when it is cold; I can smell fuel in the exhaust, but it cleans up later.
There is a lot of 3,000 rpm freeway cruising for 40-50 miles at a time. Maybe with the lift of this cam and the stock heads, it is just burning more oil? I dunno.
Re: Oil Drinking?? [Re: Magnum] #64700
05/27/08 09:23 PM
05/27/08 09:23 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
No smoke on start up. If it is, I cannot see it, or it is just fuel smoke or very very light blue. I do not see any valve seal particles in the heads under the valve covers.
The smoke while standing on the throttle or when I am going down hill is minimal and only for the initial moment when I start either driving situation.
Re: Oil Drinking?? [Re: MoparJ] #64701
05/27/08 10:53 PM
05/27/08 10:53 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
Went for another 40 mile shake down today. Only visibly saw a small bit of smoke when I jumped hard on the gas, otherwise nothing. I cleaned the plugs before I left; check again when I returned. They still look clean like they did when I checked them the first time.
I did look down number 8 cyl, which had the worse looking plug before I cleaned them. It even wasnt that bad, with a little brown oil on top of the piston. I know, if there is an issue, that it is on the right bank, as my father has followed behind me and noticed what smoke there was coming from the right side tail pipe.
Maybe the right cyl head wasnt as quality a job as the other and a valve/head job may be in line sometime in the future, not near future. I will go with 302s at that point, or milled 360 (smaller valve heads).
Sorry for the abundance of words; just trying to be descriptive.
-Justin
Re: Oil Drinking?? [Re: FuryUs] #64702
05/27/08 11:08 PM
05/27/08 11:08 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That is not right.
Re: Oil Drinking?? [Re: NITROUSN] #64703
05/27/08 11:36 PM
05/27/08 11:36 PM
Renton, WA
GreenBlurr Offline
super gas
GreenBlurr  Offline
super gas
Renton, WA
That is not right.
What are you talking about. Thats fine. Brakes to manifold vacuum on manifold, and pcv to manifold vacuum on carb is fine.
Re: Oil Drinking?? [Re: NITROUSN] #64704
05/27/08 11:39 PM
05/27/08 11:39 PM
my suggestion would be to do compression & leakdown tests.
Re: Oil Drinking?? [Re: RapidRobert] #64705
05/28/08 01:42 AM
05/28/08 01:42 AM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
Would you think that I should unplug on of my bungs in my Performer intake and try to route in the brake line there and just run the pcv only to the carb and see how it does for the situation?
Also, say it was a malseated ring. Can it seat it self ne way or the other over time? If it is not a ring (which I doubt it is) or intake gasket, i am sure it must be in the right cylnder head. It may just need more work done to it than what was performed.
All and all, given the great running condition and small amount of smoke that is present when it does happen, does this sound like something that needs immediate fixing, or is it fine for a while and wont hurt anything?
Again, sorry for the questions....
Re: Oil Drinking?? [Re: MoparJ] #64706
05/28/08 06:42 PM
05/28/08 06:42 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
Drove more today, pulled the plugs. Still, no black oil, if anything just a very very small amount of gray ash on the ends, but nothign more.
Oil still reads full after 200 miles since last quart added. Thinking about routing the brake vaccuum into the manifold and pcv to the carb tonight. Motor is running strong.
Re: Oil Drinking?? [Re: MoparJ] #64707
05/28/08 06:52 PM
05/28/08 06:52 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You're going to have to do a compression and leakdown test to be sure it's not a ring problem.
Re: Oil Drinking?? [Re: DaytonaTurbo] #64708
05/28/08 06:55 PM
05/28/08 06:55 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
Ok..
I know how to do both, but what will each point to is the numbers are low? Only ring issues?
Re: Oil Drinking?? [Re: DaytonaTurbo] #64709
05/29/08 01:28 AM
05/29/08 01:28 AM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
I performed a compression test this evening. All cylinders tested between 128 and 139, with the majority around 133-134.
I cannot see any ring problems with these numbers.
Remember, the numbers are lower, due to the larger cam with the lower compression pistons, thus lowering the cylinder pressure.
I also rerouted the brake vacuum to the manifold and pcv to the carb. The pcv does not have a baffle below it.
What do y'all think?
Re: Oil Drinking?? [Re: MoparJ] #64710
05/29/08 09:38 AM
05/29/08 09:38 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would consider pulling intake to be sure it's sealed, or maybe for now, crank the bolts down to be sure they're snug.
Re: Oil Drinking?? [Re: buildanother] #64711
05/29/08 09:44 AM
05/29/08 09:44 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
I had the same problem many years ago and my intake wasn`t sealing and it was sucking oil in from the valley. Have the heads been cut any? Mike
Re: Oil Drinking?? [Re: mopars4ever] #64712
05/29/08 11:37 AM
05/29/08 11:37 AM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
No, the heads have not been cut or shaved.
If it is an intake leak, it must be rather small, as it runs great, there is no detonation or rough idle (besides from the cam).
Page 1 of 3 1 2 3
