Educate me on cam specs and their effect on motor
#64684
05/27/08 05:54 PM
05/27/08 05:54 PM
Posts: 326 Davenport, IA
70shaker
Davenport, IA
I have a 472 Hemi with a solid roller that is a street car. It does not sound agressive enough for my taste. It is a Comp Cams with specs: lift .616 int .577 ex. 285 duration at .015 lift 110 lobe seperation
I have an old Lunati roller left over from my racing days that I am toying with installing based on input from you guys. It has specs: lift .600 int .602 ex. .320 duration at .015 lift 106 lobe seperation
I know the bigger duration will give it a more aggresive sound but what is the effect of lobe seperation on a cam's function.
Thnks in advance for educating me.
Ex Hemi Racer 70 Challenger Hemi 4 speed clone
Re: Educate me on cam specs and their effect on motor
[Re: 70shaker]
#64685
05/27/08 06:20 PM
05/27/08 06:20 PM
70shaker
Davenport, IA
Never mind guys. I should have done some checking elsewhere. The Comp Cams website has all of the info I was looking for.
[Re: 451Mopar]
#64687
05/28/08 12:36 AM
05/28/08 12:36 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
gets sound, but sacrifice vacuum, for brake booster, also get more rough iddle. Of course gets also a great boost at High RPMs ( that's why I have read )
[Re: 70shaker]
#64688
05/28/08 06:54 AM
05/28/08 06:54 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
[Re: NachoRT74]
#64689
05/28/08 07:59 AM
05/28/08 07:59 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
actually a narrow lobe separation maximizes mid-range torque and drops off faster in the upper RPM range. a wider lobe separation will flatten out the torque curve, and sacrafice a little in the midrange, but carry the torque higher in the rev range, making more upper RPM power for a given duration.
