Re: mechanical six-pack carbs. [Re: Danan] #64519
10/29/11 08:01 PM
10/29/11 08:01 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The mechanical six pack set-ups DO have accelerator pumps on the outboard carbs!!
Regarding six packs: I cannot believe how much BS (mis)information is floating around the internet, repeated and passed on my people who have never owned/run a six pack. Same thing with 426 hemis...
Yes, the mechanical secondary six pack carbs do have accelerator pumps, because they need them. It's basically just a holley double pumper spread out over 3 carbs. You need that accelerator pump shot to help cover the transition. What you definitely don't want to do is redneck a mechanical linkage to a set of vacuum carbs. That would perform horridly. Like was mentioned already, there used to be a company that would convert your vacuum carbs to have accelerator pump and mechanical linkage. But my question is at that point why wouldn't you just buy a pair of holley 2300 series carbs and run them?
Re: mechanical six-pack carbs. [Re: 70sixpkrt] #64520
10/29/11 09:02 PM
10/29/11 09:02 PM
Mississauga, On.
Duster 371 Offline
Duster 371  Offline
Mississauga, On.
I had a set brand new in the box that I sold about 6 yrs ago. I can not find pictures of it with the box and part number. Sorry.
Holley part #s were 4782 and 4783
Re: mechanical six-pack carbs. [Re: Duster 371] #64521
10/29/11 09:32 PM
10/29/11 09:32 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
bought vacuum carbs last year from summit,$440 for center$360 each outboard IIRC
Re: mechanical six-pack carbs. [Re: meepmeep70] #64522
10/30/11 03:22 AM
10/30/11 03:22 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I was talking about the Edelbrock linkage. I sold the carbs and linkage at the same time. The linkage was brand new in the box and I had a pic of the Edelbrock part #.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: mechanical six-pack carbs. [Re: 72383cudaman] #64523
10/30/11 06:17 AM
10/30/11 06:17 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
I do not have any part number for the progressive linkage. If you know of anyone with some old "Direct Connection Catalogs" the numbers should be in there, along with the numbers for the carbs too. Might be a starting point at least. Here are a couple of pics from the net over past few years of different linkages...
A True Hybrid: Burns Gas AND Rubber!
Re: mechanical six-pack carbs. [Re: fastnos] #64524
10/30/11 06:20 AM
10/30/11 06:20 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
1 more
Re: mechanical six-pack carbs. [Re: fastnos] #64525
10/30/11 06:22 AM
10/30/11 06:22 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
and another...with vaccuum secondaries
Re: mechanical six-pack carbs. [Re: fastnos] #64526
10/30/11 06:28 AM
10/30/11 06:28 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
Last one, might be able to track down one of these by old NOS number on different web sites...?
Re: mechanical six-pack carbs. [Re: fastnos] #64527
10/30/11 06:31 AM
10/30/11 06:31 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
ok, maybe another one.
Re: mechanical six-pack carbs. [Re: fastnos] #64528
10/30/11 09:10 AM
10/30/11 09:10 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I ended up with a very nice and simple heim-joint linkage from Ben at Promax. Also, using #6 banjo fuel fittings with good result & clearance.
Re: mechanical six-pack carbs. [Re: rbstroker] #64529
10/30/11 11:18 AM
10/30/11 11:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd think they'd work just as well but would require some tweaking. I think AutoZone can get you re-manned 6-pack crabs for $325 each. Or you can try and sell yours and bu a set of vacuums. In any event you're going to have to tune them.
Coming soon!!!!
Re: mechanical six-pack carbs. [Re: Mr.Yuck] #64530
10/30/11 12:09 PM
10/30/11 12:09 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
I ran three 250 CFM Holleys with a homemade linkage setup for almost a decade. The throttle response was incredible, the best I have ever had on a carbureted car. Basically it was a 750 CFM triple-pumper... Downsides were around town fuel mileage and top end power due to the 750 CFM limit... 13.6s@ 102 MPH. The carbs were meant for a 289 Cobra, and bought new at a swap meet in Houston for $40/set of three. On the end carbs, I had to cut down the extended air horns to clear the cross bars n the air cleaners.
Here's a photo of the setup:
Re: mechanical six-pack carbs. [Re: xs29j8] #64531
10/30/11 03:49 PM
10/30/11 03:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
hmm a neat trick would be to get 3 FoMoCo 550's and run them.
Re: mechanical six-pack carbs. [Re: Danan] #64532
10/30/11 04:28 PM
10/30/11 04:28 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
ain't this the truth! i made my own linkage back in the day.
Re: mechanical six-pack carbs. [Re: Duster 371] #64533
10/30/11 07:24 PM
10/30/11 07:24 PM
Stock jetting on the center carb, List # 4782 is 64 jets with a power valve and #31 squirter, the outboards call for #82 jets with #28 squirters. Measure the vacume in gear at a idle ROM and use a power valve lower than what it idles in gear(1 to 3 inches)
Re: mechanical six-pack carbs. [Re: Cab_Burge] #64534
10/30/11 09:03 PM
10/30/11 09:03 PM
oklahoma
72383cudaman Offline
oklahoma
i found someone that is going to make me linkage if i dont like the mechanical ive got 2 vaccume bodys that only need the bases can pull the switch a roo ive read both sides mechanical really dont sound too bad the ones i just bought are from the 90's from paw ive read alot of good things about the newer mechanical secondarys im not afraid to crawl up the hood of my cuda and tune
