Re: 340 Four Barrel Emblems Parts Number (3 Tab)
[Re: Speeddemon]
#644418
03/18/10 11:30 PM
03/18/10 11:30 PM
Posts: 4,785 Ontario, Canada
mccannix
Ontario, Canada
Not sure about this but does any know if the 3 tab 340 Four Barrel emblems has a different parts number then the two tab emblems? The 3 tab is for a shaker bubble.
If you are looking for cast number they are 3577361 on back of 3 pin shaker nameplate and 3442246 cast on back of 2 pin rallye hood nameplate. Part numbers are also different as listed in parts books
[Re: mccannix]
#644423
03/18/10 11:55 PM
03/18/10 11:55 PM
Posts: 327 Iowa
Speeddemon
Iowa
Pins are actually longer on the 3 pin shaker nameplates
Terry I appreciate the info on the casting #'s and photo!
[Re: B5EBody]
#644432
10/26/12 01:09 AM
10/26/12 01:09 AM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
HIGH LOW (j/k - I got lucky, didn't know they existed until ~2 years ago) These are the only two "383 MAGNUM" Dodge 3-pin emblems I've seen (used off of a '71 Challenger SHAKER bubble), I've only seen the one "440 MAGNUM" Dodge 3-pin mentioned above, & I've seen a handful of the "340 FOUR-BARREL" Dodge 3-pin hood emblems, RARE RARE RARE!
