What are the symptoms of a bad fuel pump #64362
05/27/08 06:20 AM
05/27/08 06:20 AM
Rutherfordton NC
BarryBum Offline OP
Fruit Of The Loon
BarryBum  Offline OP
Fruit Of The Loon
Rutherfordton NC
I am having a fuel delivery problem on my little Scamp. It seems as if its running out of fuel. When it does this, I can take the line loose at the pump suction and there is nothing there. If a pump goes bad, can it blow through the check valve and pump fuel backward?? If a pump is bad, is if sporadic? I've got a new tank, new sending unit, clean lines, new filter..........not sure what else it could be??
Re: What are the symptoms of a bad fuel pump [Re: BarryBum] #64363
05/27/08 08:56 AM
05/27/08 08:56 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Sounds like everything is new except the pump. Have you checked your lines for leaks??
When going bad a pump will start out losing pressure so that at WOT you will experience fuel starvation. They can work intermittently for a while but eventually it will act like a plugged fuel filter before dying all together.
Re: What are the symptoms of a bad fuel pump [Re: BarryBum] #64364
05/27/08 09:48 AM
05/27/08 09:48 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Run a piece of hose from the suction side of the pump to a temporary gas tank close to the pump. If the pump picks up and runs fine, you have a problem with your lines or new sending unit. Also try removing your gas cap when the trouble occurs. You may have a blocked vent.
Re: What are the symptoms of a bad fuel pump [Re: dmerc] #64365
05/27/08 10:33 AM
05/27/08 10:33 AM
Rutherfordton NC
BarryBum Offline OP
Fruit Of The Loon
BarryBum  Offline OP
Fruit Of The Loon
Rutherfordton NC
speaking of blocked vent. That sending unit had a little tube that went to nowhere. Was that a vent? I have it blocked off right now cause I couldn't find a line that went to it. It still does have the vent that goes to the charcoal can though on the very top of the tank. What does that other little tube do and where does it go?
Re: What are the symptoms of a bad fuel pump [Re: BarryBum] #64366
05/27/08 06:34 PM
05/27/08 06:34 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Ya, that's a vent. You can use it as a return line if you have a set up that has a return line. Hope your new sending unit isn't as inaccurate as mine was.
