interested in a A/W for blow thru? #643174
03/17/10 04:39 PM
03/17/10 04:39 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
made to your needs but for now just big enough for 800 to 1,000HP.my brother has had hundreds made for motorcycles using 30lbs of boost.i think he can make 1 for the budget minded build.the core is a little bigger than 4"X4"X10".
this is a bike 1 with a BOV fitting.
http://s27.photobucket.com/albums/c192/b...pg&newest=1
Re: interested in a A/W for blow thru? [Re: blownzoom440] #643175
03/17/10 08:55 PM
03/17/10 08:55 PM
Tampa, Fl
valiantboy Offline
super gas
valiantboy  Offline
super gas
Tampa, Fl
looks nice. real compact too. whats the cfm rating and pres drop? what will somthing like that cost?
I'm WAY too baked to drive to the devil's house.
Re: interested in a A/W for blow thru? [Re: blownzoom440] #643176
03/18/10 12:37 PM
03/18/10 12:37 PM
michigan
Steve Morris Offline
michigan
Thats neat, what cores?
Re: interested in a A/W for blow thru? [Re: Steve Morris] #643177
03/18/10 01:12 PM
03/18/10 01:12 PM
SRQ, FL
8valves Offline
8valves  Offline
SRQ, FL
From his power level and dimensions and looks, I'd say they are garrett cores. Really nice pieces. Much nicer than the spearco/t-netics stuff in my opinion.
Aaron M
Re: interested in a A/W for blow thru? [Re: 8valves] #643178
03/18/10 04:02 PM
03/18/10 04:02 PM
ELYRIA,OH
ELYRIA,OH
well i talked to him and not that he would not do it.he said some1 makes them for about 500$.it was my idea this whole thing.if you dont like the other cores and still interested i will keep talking about it to him.the core shown has 1/2lb drop but at 30 psi.it flows 850hp.for 1,000hp at 14psi lets say a core 4x8x12 wouls be better.the site that sells the cooler for 500$ is on cooled boost or chilled boost.com.i will have to check it out.lets see what is out there.
Re: interested in a A/W for blow thru? [Re: blownzoom440] #643179
03/19/10 03:47 AM
03/19/10 03:47 AM
ELYRIA,OH
ELYRIA,OH
any core could be used depending on your needs.[made to fit]what shape in/out would suit your needs.slip on hose?V band?i would like to see theis mounted in front of the engine going to the carb and fit well.
Re: interested in a A/W for blow thru? [Re: blownzoom440] #643180
03/24/10 09:08 AM
03/24/10 09:08 AM
ELYRIA,OH
ELYRIA,OH
i could not find the I/C for 500$ but chiseled performance has something in the 850$ range so you can have an idea what it might cost.the intercooler in the picture above for the motorcycle cost over 1100$.
Re: interested in a A/W for blow thru? [Re: blownzoom440] #643181
04/01/10 04:40 PM
04/01/10 04:40 PM
Antioch, CA
lucky13 Offline
lucky13  Offline
Antioch, CA
try www.frozenboost.com thats probably what he was talking about
www.racemagnum.com
1954 Plymouth Savoy 2 door
Re: interested in a A/W for blow thru? [Re: lucky13] #643182
04/02/10 09:06 AM
04/02/10 09:06 AM
ELYRIA,OH
ELYRIA,OH
that looks like it would be it.the largest would be my choice. i dont know about those welds though!
