LA Valve cover on Magnum head? #64213
05/26/08 08:42 PM
05/26/08 08:42 PM
Vista, California
ChickMaggot Offline OP
Vista, California
Visually, it doesn't appear that it will work, but I've heard some of you guys say it's possible. Anyone ever tried it?
I'd like to go Magnum, but I'd also like to keep my M/T's.
You can lead a gift horse to water, but you
can't look in his mouth.
Re: LA Valve cover on Magnum head? [Re: ChickMaggot] #64214
05/26/08 09:03 PM
05/26/08 09:03 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
i run them on my magnum heads with no problems at all go for it
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: LA Valve cover on Magnum head? [Re: aspenrt360] #64215
05/26/08 10:29 PM
05/26/08 10:29 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I run stock '68 318 valve covers on my Mag heads, no leaks, no troubles. I used the gray MP re-usable LA valve cover gaskets, glued to the valve cover, nothing between the gasket and the Mag head.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: LA Valve cover on Magnum head? [Re: ChickMaggot] #64216
05/27/08 08:40 AM
05/27/08 08:40 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
I have the cast MP LA covers on my magnum heads, I am also using the MP composite LA valve cover gasket. It's over 20K miles with no leaks and I have had the valve covers on an off several times with the same composite gasket too.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: LA Valve cover on Magnum head? [Re: dgc333] #64217
05/27/08 09:54 AM
05/27/08 09:54 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Are bolt holes in the same location? Don`t know just asking? Mike
Re: LA Valve cover on Magnum head? [Re: mopars4ever] #64218
05/27/08 09:59 AM
05/27/08 09:59 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
5 out of 10 bolts are in the right place...
Tony
70 AARCuda Vitamin C
Re: LA Valve cover on Magnum head? [Re: 70AARcuda] #64219
05/27/08 01:00 PM
05/27/08 01:00 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Re: LA Valve cover on Magnum head? [Re: Devil] #64220
05/27/08 03:58 PM
05/27/08 03:58 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
cheapo summit $20 valve covers, with cheapo fel-pro gaskets on mine. No leaks so far
Re: LA Valve cover on Magnum head? [Re: ChickMaggot] #64221
05/27/08 08:03 PM
05/27/08 08:03 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
I have the magnum motor with the serpentine accessory brackets on my truck. I tried the LA valve covers on my mag motor and they hit the back of the alternator. this is a 2000 motor.
I have heard of some using them and they do line up, some seal good some leak..its a crap shoot.
Id say try it especially since mopar valve covers for the mag motor are expensive...like 200.00 a pair.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: LA Valve cover on Magnum head? [Re: blk00rt] #64222
05/27/08 11:51 PM
05/27/08 11:51 PM
Vista, California
Vista, California
Thanks for all the input guys. I'm pretty confident in picking up a crate motor and having it look cosmetically pleasing. Looks like my 360 exhaust manifolds will even work as well.
