torsion bars #641623
03/16/10 07:53 AM
03/16/10 07:53 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Does it make any difference which end goes in first? Thanks
Re: torsion bars [Re: 70 buzz] #641624
03/16/10 08:34 AM
03/16/10 08:34 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
No, but some are marked left and right side.
Re: torsion bars [Re: 70 buzz] #641625
03/16/10 08:56 AM
03/16/10 08:56 AM
LENOX , MI
KMPX2 Offline
mopar addict
KMPX2  Offline
mopar addict
LENOX , MI
If they are used yes it does.
Re: torsion bars [Re: KMPX2] #641626
03/16/10 10:16 AM
03/16/10 10:16 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
which end goes first ? well, mostly of cases you make them fit allmost at the same time. At least I fit them with LCA already on K member
now some extra info.
no difference between rear and front... does't affect even being used.
think on a bolt and nut. No matter wich side you tight, nut or bolt head, allways will be on the same direction. Get it reversed, and will still tight the same direction.
the only important thing is keep the left on left and the right on right.
what is very common but not mandatory is keep the PN visible on rear
Re: torsion bars [Re: NachoRT74] #641627
03/16/10 10:24 AM
03/16/10 10:24 AM
Makes it easy to ID what you have in there if you lose track but can go in either way. If your bars have a L and a R or an odd and an even # to dictate which side they go that is critical and on the ones that are not marked and are therefore not side specific either side is OK unless they are used in which case they need to be marked and returned to the same side as before.
Re: torsion bars [Re: RapidRobert] #641628
03/16/10 02:21 PM
03/16/10 02:21 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Thanks, the bars that I have are marked L&R
Re: torsion bars [Re: 70 buzz] #641629
03/17/10 02:40 AM
03/17/10 02:40 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
They twist the same direction regardless of which end goes forward. Getting the left and right side bar in the correct spot is very important.
