Re: Flow testing heads?
[Re: blowndart]
#641096
03/15/10 07:04 PM
03/15/10 07:04 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Usually $40-50.00 a port. Some guys will discount a bit if flowing all the ports.
RIP Monte Smith
[Re: blowndart]
#641097
03/15/10 07:27 PM
03/15/10 07:27 PM
some guys will do it for a little less if they already have checking springs on them. it saves them a few minutes from disassembling, etc.
[Re: CompWedgeEngines]
#641098
03/15/10 08:00 PM
03/15/10 08:00 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
Did not realize it could run up to $800 for a set of heads. I may have to rethink that idea.
[Re: blowndart]
#641099
03/15/10 08:11 PM
03/15/10 08:11 PM
Posts: 1,051 The Great White North
RAMM
I charge $ 60 for the first cylinder-$30 for any additional cylinders. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: blowndart]
#641100
03/15/10 09:56 PM
03/15/10 09:56 PM
BradH
FWIW, most people don't have EVERY port tested, only one cylinder per head to check for some consistency.
[Re: blowndart]
#641101
03/15/10 09:57 PM
03/15/10 09:57 PM
CompWedgeEngines
Syracuse,NY
My bad on choice of words..I meant per cylinder, not per PORT. I automatically know its a pair of ports, but didnt type that. Sorry for the shock...lol.
RIP Monte Smith
#641103
03/16/10 07:09 AM
03/16/10 07:09 AM
blowndart
Odessa, Fl
OK. That seems more reasonable then.
