Re: Will this car leave straight? Corner weights--
[Re: rt66jim]
#640477
03/15/10 06:17 PM
03/15/10 06:17 PM
He intends to run it as it is right now to start. I just wanted to be sure we were close enough. Didn't want to have to worry about him getting in the guardrail or the weeds. Jim
i'd worry, i bet you go to the right. this ought to be interesting. especially if your on a marginal track.
#640478
03/15/10 06:34 PM
03/15/10 06:34 PM
Posts: 1,303 Penna
70satelliteguy
Penna
All kidding aside those numbers are typical of a lot of BB A body ladder bar cars, go run it. the wheelie heights and distances will be determine by track conditions, tires, stall leaving the line and several other factors like front and rear shock adjustments and travel Bob George had me set up my Ladderbars neutral ! With driver in place I have 846 RR and 852 LR with about 60 lbs. more on the LF than on the rF. 52& front and 48% Rear. Our car also goes straight as an arrow even with some pretty good wheel stands set up this way with 60 fts, in the 1:31 range. BB B Body 3600 lbs. with driver! Mike
[Re: Cab_Burge]
#640480
03/15/10 09:43 PM
03/15/10 09:43 PM
dartman366
Mt. Vernon, Ohio
when we set up the weight in my car we set it up as even side to side in the rear as we could, car went right a little, added 30# preload to the right rear and the car has been on a rail ever since,,
[Re: dartman366]
#640481
03/15/10 09:56 PM
03/15/10 09:56 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
30-60 is the range for LB back half cars.....4 link cars 20-40 works good....if anti-roll is used...zero across the board. BTW....aren't you glad you listened?...
