Mod's to put 28" tall front tire on a duster/demon?
#638962
03/13/10 05:01 PM
03/13/10 05:01 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
For those of you that have 28" tall tires on the front of your duster, what mod's did you have to do to make it happen? What wheel offset? How wide of a tire? Did you trim the fender at all? Mine is getting closer to paint, and I'd just rather do this now then later if I have to... Thanks!
Re: Mod's to put 28" tall front tire on a duster/demon?
[Re: Locomotion]
#638965
03/13/10 08:55 PM
03/13/10 08:55 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
ditto... watch out also if youve got the wheel turned alot and you pull in or out of an elevation like a driveway/bump.. it can hit the wheel well lip at around 11oclock youll notice a small indentation on the factory portion of the inner lip..its folded in a little extra bit..it hits right there.. i took a body hammer and dolly and massaged it up a little bit more.. that and the aformention'd front edge.. put a nice sipe in the outer edge of the tire first time i backed up with the wheel turned just right...fwiw. cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: John Burdine]
#638967
03/14/10 01:58 PM
03/14/10 01:58 PM
dizuster
Oakland, MI
So is it just the lip, or does the outside fender itself need to get trimmed/rolled? Anyone got pictures? Thanks for all of the replies!
[Re: dizuster]
#638968
03/15/10 01:48 PM
03/15/10 01:48 PM
Posts: 1,880 USA
Ron Silva
USA
I run a 2.25 backspace wheel and trim the lower front edge of the wheel opening and then make a new strut/brace a little bit longer to push the fender out more. Just take 1/2" aluminum drink machine tubing straighten and smash the ends flat and drill.
On this car I actually made my wheel opening bigger and profiled the bottom edge since my car had to be painted as well.
The main lip of the wheel opening does not need to be rolled. I have never done that.
SRT DEMON ONE SEAT
[Re: Monte_Smith]
#638972
03/16/10 07:11 AM
03/16/10 07:11 AM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
My question would be....why do you guys run such a tall tire on the front. Whats the purpose
Monte
I've got 26" tires now. I tried it when my car sat higher.
[Re: Monte_Smith]
#638974
03/16/10 08:58 AM
03/16/10 08:58 AM
Posts: 5,898 Florida
Locomotion
Monte
At the track, to syncronize vehicle reaction times to a comfortable spot on the tree for the driver!
