Heat riser or not.
#636603
03/11/10 11:23 AM
03/11/10 11:23 AM
Posts: 670 Third rock from the sun.
busboy
I have two sets of exhaust manifolds. One has the heat riser valve removed and the hole welded shut, the other has the valve intact and working. For my summer only driven car, which one should I run? or does it matter? Both sets are 68/69 big block hipo manifolds.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Heat riser or not.
[Re: busboy]
#636609
03/13/10 07:16 PM
03/13/10 07:16 PM
RapidRobert
I'd run a carb spacer of whatever height your hood will allow and next time you change intakes I'd use a blocked valley pan. Todays gas is not made for carb'ed cars and it's vapor pressure resistance lets it boil at a MUCH lower temp than the 60's gas formulations in use when the heat risers were oe equipment
