Anyone running a keisler 5 speed with TTi headers?
#636155
03/10/10 09:13 PM
03/10/10 09:13 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
Curious if anyone else is running a keisler 5 speed with TTi 2" big block headers. I know I cant be alone.
I have an issue with the keisler set up that they dont mention to you. After installation of the 5 speed my headers are now 2" off the ground. I under stand that the keisler set up changes your driveline angle which lowers the headers.
Anyone have any ideas on fixing this? I need to get the headers and the exhaust back up where they belong.... it looks like crap!!!
Anyone think a good exhaust shop could bend the headers?
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
Re: Anyone running a keisler 5 speed with TTi headers?
[Re: 69charger440_6pa]
#636157
03/10/10 10:11 PM
03/10/10 10:11 PM
Posts: 265 Garland, Texas
1badmopar
Garland, Texas
I would like to know more about this issue as well. My Keisler and TTIs are being shipped as we speak. They should arrive within the next week, and this makes me very nervous.
I thought the trans was modified so that you did not have to alter the drive line angle. i.e. notching the rear shift mount to clear the torsion bar cross member.
Can you post a pic of your clearance issue so I can better understand what I am about to walk into?
1966 Plymouth Belvedere 520" RB w/ Indy 440-1 Heads FiTech Fuel Injection TKO 600 conversion [img] https://flic.kr/p/2j1ejsK[/img]
#636164
03/10/10 11:25 PM
03/10/10 11:25 PM
Posts: 2,042 MD
RTSE4ME
MD
Also you may have interference with the steering hitting the oil pan, and possibly the steering arm hitting the header.
I have plenty of clearance with 2" TTIs. I am running the long fast ratio arms and even those have plenty of room. One thing people may not realize is the 1 7/8" and 2" TTIs are completely different in design.
#636166
03/10/10 11:48 PM
03/10/10 11:48 PM
Posts: 18,157 Mass
DAYCLONA
Mass
IIRC many months ago Ryan you asked about the Keisler install in the 68-70 B body charger, and I mentioned that you should split the transmission tunnel starting from the firewall/floor seam back to the shifter location, and open up the floor so that you have a wedged seam approx 2" wide up front (near the firewall) tapering to 0 at the shifter hole, then weld in a filler strip,...is your car still equipped with the automatic floor hump, are you using a factory 4 speed hump?, if your interference is up front on the passenger side "ear" located on the transmission, cut it off, it does nothing but hit the floor, I've said it many times before regardless of the body install, mod the floor to achieve the proper driveline angle, if your afraid of modding the floor, then a Keisler isn't in the "cards" for you.....I have the Keisler prototype 68-70 B body TKO 600/650 5 spd which is much bulkier than the production units, I fabricated my own spacer to achieve the original driveline angle, along with mods to the tunnel, even after the rug was down, you can't tell the difference, nevermind with a console atop the whole thing Mike
[Re: DAYCLONA]
#636167
03/11/10 12:34 AM
03/11/10 12:34 AM
69charger440_6pa
Oakley CA
It's a 4 speed car and I really didn't want to cut up the tunnel, just in case I want to take it back to stock some day. Guess I'll just have to though.
[Re: DAYCLONA]
#636169
03/11/10 01:39 AM
03/11/10 01:39 AM
69charger440_6pa
Oakley CA
Do you have any pics of a modded tunnel?
#636170
03/11/10 02:19 AM
03/11/10 02:19 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: General 68]
#636172
03/11/10 01:30 PM
03/11/10 01:30 PM
69charger440_6pa
Oakley CA
Alright looks like I'll be doing some surgery on the car to get this thing to fit right...... just wish that Keisler would have told me this.
If anyone has any pics of a modded tunnel I would like to see them.
Thanks guys.
[Re: Kirby]
#636175
03/11/10 05:42 PM
03/11/10 05:42 PM
Posts: 144 Blair, NE
cudacam
Blair, NE
So when I was told that their tranny would go right in my 71 Cuda' (has 4 speed hump) they were not accurate/honest, and I will have to modify my hump still? Man I'm gonna be hot if that's the case! Means I have to pretty much gut my car? I wondered when the kit came with the sheet metal piece. Too late even at that point.
Oh, it will "go right in" but the tail-end will probably be to low for proper drive-line geometry... depending on your ride height. The tunnel mod wasn't hard (I already had the hump too) and I didn't care about cutting my car. But if you don't want to cut....
All you can do is test fit and see how it looks.
[Re: 72roadrunnergtx]
#636177
03/11/10 10:45 PM
03/11/10 10:45 PM
69charger440_6pa
Oakley CA
So whats the best way to go about cutting? I obviously need to pull the console and the carpet. I would like to not have to pull the tranny. Dayclona so if I understand you correctly. I need to make a cut that goes from the shift hole, to the firewall seem. That cut is going to spread outwards as it makes it closer to the firewall. I will also need to bend or cut the flange under the tranny tunnel. Make a patch weld it in and reassemble? By doing this I will be able to tuck those headers up nice and high and actually pull in my garage without dragging them
#636178
03/12/10 02:13 AM
03/12/10 02:13 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Ryan the way Doug chose to increase the height of the tranny tunnel is favorable to, as I said the Tremec is a tall (vertical) case, in my install in the 70 B body, I could have left the floor stock, and would have had to deal with rephaseing the driveline, which you will be REQUIRED to check/confirm and perform anyway, but apon intial checking with a inclination meter, determined the angles were to radical, so I cut a seam from the shifter opening were the Keisler shift tower protrudes straight up the center to the floor/firewall seam, them made a cut across the seam, basically a "T" shaped cut, then pulled the seam open starting at the firewall/floor seam, the filler strip was about 2" wide, 2 ft long,,,tapering to a point at the shifter hole,.....Keisler applications vary from body to body, engine to engine, some cars I've done, no floor mods needed, other than a 4 speed hump, some cars are mildly modded on the floor, some radical,....but basically I firmly believe the driveline angle should be proper, regardless of what has to be done to the trans tunnel or brace, the benefits of the Keisler far outway the merits of so-called "originality" regarding the tranny tunnel
Mike
[Re: Kirby]
#636179
03/12/10 02:35 AM
03/12/10 02:35 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Kirby keep in mind your kit you just purchased is recent, the E body kit has undergone more upgrades since it's inception than perhaps any other Keisler kit,.....I changed out an old E body Keisler install, not to long ago, done back originally in 2002 by a customer,....had the customer send the tranny into Keisler for current upgrades, hyd. TOB, case mods, and new 3rd Gen shifter install,....it was like night and day, the tranny now tucked up higher in the tunnel with no mods to the floor, shifted better, plus the driveline angle was greatly restored back to "original" as this customers car suffered from a poor driveline angle for the sake of not modding the floor, which the customer still wanted to retain original, the end result was a 3 degree shim to the axle perches to rephase the driveline....this Keisler TKO being a very early model, lacked the current upgrades done to the new cases/kits,...so IMHO go about the install as you would installing a 4 speed, and check the driveline angle of your exsisting set up verses the Keisler install, if you prefer a preliminary mock up, just the bell. tranny, and tranny mount to establish a baseline in which to make a determination regarding the driveline angle, before making the complete install..
Mike
[Re: Challenger_Nut]
#636180
03/12/10 10:47 AM
03/12/10 10:47 AM
Posts: 869 Sugarloaf, PA. USA
JamiePasson
Sugarloaf, PA. USA
One more reason to pray that Passon gets his new design 5-speed right.
Oh, it will be right, or it won't be sold. I have been very attentive to some of the "issues" that have arrived with the kits that "don't require cutting." I will not make the same mistakes that those have made previously. Jamie
[Re: DAYCLONA]
#636181
03/12/10 12:24 PM
03/12/10 12:24 PM
Posts: 1,527 minnesota
Kirby
minnesota
I hope your are right. Thanks Mike!
Mike
[Re: Kirby]
#636182
03/13/10 10:11 PM
03/13/10 10:11 PM
69charger440_6pa
Oakley CA
OK so I got the car up in the air today and started looking a little closer at everything.
It looks like making things fit in the tunnel will be very easy, however I have a question about the torsion bar crossmember.
It looks like I barley have 1" of play room. My TKO is a newer "modded" one by keisler. Have any of you had to modify your crossmember? Or is that 1" enough room to make things right?
#636183
03/13/10 10:26 PM
03/13/10 10:26 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Ryan,....I didn't have to touch the torsion bar crossmember in my Keisler TKO 600 1970 Charger install, although it's very close about 1/2" clearance between the crossmember and the transmission, it causes no contact issuses, just make sure to have enough clearance around the shift tower as it protrudes thru the floor,for when the driveline torques over. if you remove the shift tower during install, it's easy to mistakenly install it 180 degrees, the "flat" machined on the shifter attachment nub where the shifter bolts to, faces the drivers side....
For future reference, If you remove the shift tower at any time and have problems installing it later, or the shifter seems" jambed" in gear and won't move, it's because the transmission wasn't in neutral during the shift tower install, here's a pic of where the internal shift rods should be for "neutral" to properly reinstall the shift tower
Mike
[Re: DAYCLONA]
#636184
03/13/10 10:29 PM
03/13/10 10:29 PM
69charger440_6pa
Oakley CA
Mike
OK thanks!
[Re: NITROUSN]
#636198
03/14/10 12:26 AM
03/14/10 12:26 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I do not have my car assembled. But I did do a mock up. I have a hemi with 2 1/8 tti headers.
Pete did you mock up the headers on the engine with the bellhousing in place as well,..SOME TTI's header tubes on the passenger side will contact the lower lip of the Keisler bellhousing where the inspection cover bolts too,...may need a trim on the corner flange of the bells inspection cover lip, otherwise it puts stress on the header flange as you bolt it to the engine, or if the engine is in with the headers bolted, you won't be able to mount the bellhousing due to interference
Mike
[Re: DAYCLONA]
#636199
03/14/10 12:35 AM
03/14/10 12:35 AM
Posts: 18,407 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Mike if you mean where number 2 tube runs? Yes I did make some minor mods. Cant remember what I did as it was so mind frightning. Not for the weak of heart [lol].
[Re: NITROUSN]
#636200
03/14/10 12:36 AM
03/14/10 12:36 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Looks good Pete,....sitting up high in the tunnel like it should,...I notice your not running a 4 spd factory hump?....you'd gain a little more room around the tranny with it,....would really help with heat, as the Keisler when driven in OD mode for extended time periods puts off enough heat to fry Bacon and eggs on it ....you should put down some dynamat, the non adhesive foil kind, any adhesive, esp the tar type will only heat up and stink out your car Pete,...did you ever get the 3rd gen shift tower from Richard at Keisler to upgrade?...as I see the Gen 1 in your pics Mike
[Re: DAYCLONA]
#636202
03/14/10 12:57 AM
03/14/10 12:57 AM
NITROUSN
Mike I did get the upgraded tower. A while back when I posted some pics you mentioned that there could be some minor issues, I was contacted by the guys at keisler and sent upgraded parts at no charge. It is obvious that they watch and respond to the buyers of their products. While I have to admit my project is not mobile I have had support. There again I went by direction and cut the hole in the floor as told. I did it my way and all told the included templete was just about spot on.
We may have to talk one day.
[Re: NITROUSN]
#636203
03/14/10 01:18 AM
03/14/10 01:18 AM
Posts: 18,157 Mass
DAYCLONA
Mass
#636205
03/14/10 06:10 PM
03/14/10 06:10 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Well, seats are out, carpet is out and tunnel ready to be "modified". The cutting will begin tomorrow!
Do yourself a favor Ryan and purchase a magnetic inclination meter to measure the transmission centerline in relation to the drive shaft, and rear pinion angle, so that you can "dial in" your set up as recommended in your Keisler install instructions
These are listed in McMaster Carr, they range from $8-$45
Mike
[Re: DAYCLONA]
#636206
03/14/10 06:41 PM
03/14/10 06:41 PM
69charger440_6pa
Oakley CA
I have one, thanks for the heads up
