Re: 3.91 or 4.30 gears for the street and track? [Re: Barnstorm] #635956
03/11/10 03:05 PM
03/11/10 03:05 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Surprised several years ago a buddy talked me into replacing my 3.91's with 3.23's. Ran 12.20's and 112 w/3.91's and 12.40's at 111 w/3.23's. Mileage went from 9 to 13 one the road, 65mph. Motor makes 511hp 580tq 500in...it doesn't care much for a deep gear. Torque motor.
you lost a 1/4 second with the gear change! thats a lot!!!!
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: 3.91 or 4.30 gears for the street and track? [Re: 67dodge67] #635957
03/11/10 03:07 PM
03/11/10 03:07 PM
Long Island, NY.
Stroked65Belv Offline
Long Island, NY.
I run a 496/440 stroker, currently with 4.30 and 727 with 3000 stall. I had a 28" tire, @55mph 3000rpm. Went to a 29" tire and dropped approx. 150-200 rpm at same speed. I plan to switch to 3.91 myself and have a lil more driveability in the car. The 3.73 is also an option as well. The more cubes(stroker) = more torque. I dont think you need 4.30 as others suggested here youd run out of motor at the end of the strip. Keep the motor in its powerband longer other then way upstairs where you may come up short. The taller tire (29x11.50x15 Hoosier DOT slick 15x8"rim) in itself helped me a lot. Slightly taller and more rubber on the street. Blows away drag radials.
Try a dyno, possibly will find your powerband target zone and help you decide better.
Good luck.
Re: 3.91 or 4.30 gears for the street and track? [Re: aarcuda] #635958
03/11/10 03:56 PM
03/11/10 03:56 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Don't care...tough to tell the diff...car is much more driveable on the hiway...I can still go rounds at 12.40.
The little old lady from Pasadena is back!
Re: 3.91 or 4.30 gears for the street and track? [Re: aarcuda] #635959
03/11/10 07:14 PM
03/11/10 07:14 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
1/5th the way I calculate it. For the mileage increase, and possibly feeling better when taking it on the freeway, not that bad of a sacrifice..
Re: 3.91 or 4.30 gears for the street and track? [Re: 67dodge67] #635960
03/11/10 09:35 PM
03/11/10 09:35 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
A diff spin on all this .....
Big torque motor .. not a super heavy-weight car ...... and a real "streeter" ? ...
....GO WITH the shortest gear possible ... ie 2.76.
Your short-times(60 foot) will suffer a TAD but you will LOVE the driveability on the highway.
HOW would you like to a ZR1 Corvette from a 100-roll ? ..
Re: 3.91 or 4.30 gears for the street and track? [Re: dOc !] #635961
03/11/10 10:17 PM
03/11/10 10:17 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
We don't have and 2.76 pumpkins around, but I'd try one if we did. purpose built torque motor for the street...give me 400 less rpms at 60 and maybe I can get 16mpg and now run 12.60's.
Re: 3.91 or 4.30 gears for the street and track? [Re: Barnstorm] #635962
03/11/10 10:34 PM
03/11/10 10:34 PM
Florida STAYcation
Florida STAYcation
THERE ya go ... Now I have a lite-weight 62 Belvedere, just a basic-HP rebuild, iron manifolds ... 276 gear ..
and it should run 12.30's and get near 20 mpg(if not more).
Re: 3.91 or 4.30 gears for the street and track? [Re: dOc !] #635963
03/11/10 11:05 PM
03/11/10 11:05 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Maybe Slantzilla has some thing that runs 12's and gets 30mpg.
Re: 3.91 or 4.30 gears for the street and track? [Re: Barnstorm] #635964
03/12/10 01:21 AM
03/12/10 01:21 AM
WI, USA
67dodge67 Offline OP
mopar addict
mopar addict
WI, USA
wow! this is interesting how my initial post has changed! haha no worries.... i'm following this and trying to get anything from it. hmmm...
Re: 3.91 or 4.30 gears for the street and track? [Re: 67dodge67] #635965
03/12/10 01:25 AM
03/12/10 01:25 AM
I gave up on deep gears years ago after putting 4.56 gears in a street car and hating them.
Big surprise, went back to 3.23's and really didn't change e.t. at the strip!
Deepest I'll go with a street car now is 3.55's.
If I want better e.t.'s I'll throw a buttload of stall in the convertor at it.
Re: 3.91 or 4.30 gears for the street and track? [Re: Barnstorm] #635966
03/12/10 01:29 AM
03/12/10 01:29 AM
Florida STAYcation
Florida STAYcation
Hey HAY ...was this a jab ? ....
I had a junk-yard 440 in there ...and it ran 12.80's and got 17.
So THERE ....
And slant ...with his 'Tona ....maybe could get 40.
Re: 3.91 or 4.30 gears for the street and track? [Re: Dougsmopars] #635967
03/12/10 01:29 AM
03/12/10 01:29 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
3:Top speed on high way will be around 60 and taching around 3800 to 4000. I
Unless you have 24 inch tall tires your converter needs help........
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 3.91 or 4.30 gears for the street and track? #635968
03/12/10 01:33 AM
03/12/10 01:33 AM
WI, USA
mopar addict
mopar addict
WI, USA
OK... so that leads to my next question then.... why would you overkill your converter if your powerband is between 2600 - 5800? I'm going by what I have experienced driving it on the track... not the true numbers.
SOOOO my converter as of now is a PTC 11" and rated at 2800 which is AWESOME now. SOOOO would a 3000 or 3500 stall be that much better? That would be a 10" or a 9"? Sorry, converters are not my best subject (recap on my set up: 470, 727, 3.91, eddy rpm heads, rpm intake, 830 quick fuel, voodoo cam 513 intake, 533 ehxaust)
I'm open to any and all suggestions.
Thanks!
Re: 3.91 or 4.30 gears for the street and track? [Re: 67dodge67] #635969
03/12/10 02:38 AM
03/12/10 02:38 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
converter also maens better efficiency of transferring power from motor to trans...on down
I have a 69 bee with a 30 over 440 6 pack setup and 410's but will run My plymouth...67..with a 498 stroker..auto...355's..with a 2200 to 2800 stahl...If I don't get into 11's I will first improve the converter
