Re: 3.91 or 4.30 gears for the street and track?
[Re: aarcuda]
#635958
03/11/10 03:56 PM
03/11/10 03:56 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Don't care...tough to tell the diff...car is much more driveable on the hiway...I can still go rounds at 12.40.
The little old lady from Pasadena is back!
[Re: aarcuda]
#635959
03/11/10 07:14 PM
03/11/10 07:14 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Surprised several years ago a buddy talked me into replacing my 3.91's with 3.23's. Ran 12.20's and 112 w/3.91's and 12.40's at 111 w/3.23's. Mileage went from 9 to 13 one the road, 65mph. Motor makes 511hp 580tq 500in...it doesn't care much for a deep gear. Torque motor.
you lost a 1/4 second with the gear change! thats a lot!!!!
1/5th the way I calculate it. For the mileage increase, and possibly feeling better when taking it on the freeway, not that bad of a sacrifice..
[Re: 67dodge67]
#635960
03/11/10 09:35 PM
03/11/10 09:35 PM
Posts: 30,547 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
A diff spin on all this ..... Big torque motor .. not a super heavy-weight car ...... and a real "streeter" ? ... ....GO WITH the shortest gear possible ... ie 2.76. Your short-times(60 foot) will suffer a TAD but you will LOVE the driveability on the highway. HOW would you like to ![](/ubbthreads/images/graemlins/hammer.gif) a ZR1 Corvette from a 100-roll ? .. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: dOc !]
#635961
03/11/10 10:17 PM
03/11/10 10:17 PM
Barnstorm
Minnesota
We don't have and 2.76 pumpkins around, but I'd try one if we did. purpose built torque motor for the street...give me 400 less rpms at 60 and maybe I can get 16mpg and now run 12.60's.
[Re: Barnstorm]
#635962
03/11/10 10:34 PM
03/11/10 10:34 PM
dOc !
Florida STAYcation
THERE ya go ... Now I have a lite-weight 62 Belvedere, just a basic-HP rebuild, iron manifolds ... 276 gear ..
and it should run 12.30's and get near 20 mpg(if not more).
[Re: dOc !]
#635963
03/11/10 11:05 PM
03/11/10 11:05 PM
Barnstorm
Minnesota
Maybe Slantzilla has some thing that runs 12's and gets 30mpg.
[Re: 67dodge67]
#635965
03/12/10 01:25 AM
03/12/10 01:25 AM
I gave up on deep gears years ago after putting 4.56 gears in a street car and hating them. Big surprise, went back to 3.23's and really didn't change e.t. at the strip! Deepest I'll go with a street car now is 3.55's. If I want better e.t.'s I'll throw a buttload of stall in the convertor at it. ![](/ubbthreads/images/graemlins/burnout.gif)
[Re: Barnstorm]
#635966
03/12/10 01:29 AM
03/12/10 01:29 AM
dOc !
Florida STAYcation
Hey HAY ...was this a jab ? .... ![](/ubbthreads/images/graemlins/laugh2.gif)
I had a junk-yard 440 in there ...and it ran 12.80's and got 17.
So THERE .... ![](/ubbthreads/images/graemlins/tsk.gif)
And slant ...with his 'Tona ....maybe could get 40.
[Re: Dougsmopars]
#635967
03/12/10 01:29 AM
03/12/10 01:29 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
3:Top speed on high way will be around 60 and taching around 3800 to 4000. I
Unless you have 24 inch tall tires your converter needs help........
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
#635968
03/12/10 01:33 AM
03/12/10 01:33 AM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
OK... so that leads to my next question then.... why would you overkill your converter if your powerband is between 2600 - 5800? I'm going by what I have experienced driving it on the track... not the true numbers. SOOOO my converter as of now is a PTC 11" and rated at 2800 which is AWESOME now. SOOOO would a 3000 or 3500 stall be that much better? That would be a 10" or a 9"? Sorry, converters are not my best subject (recap on my set up: 470, 727, 3.91, eddy rpm heads, rpm intake, 830 quick fuel, voodoo cam 513 intake, 533 ehxaust) I'm open to any and all suggestions. Thanks! ![](/ubbthreads/images/graemlins/thumbs.gif)
