Asking for tips-Painting the plastic radiator shroud #63506
05/25/08 09:16 PM
05/25/08 09:16 PM
Myrtle Beach, SC formerly the ...
340wedge Offline OP
340wedge  Offline OP
I am looking to paint my radiator shroud due to paint overspray and aging. Is there a paint, flat black or something to keep the natural plastic look.?
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Asking for tips-Painting the plastic radiator shroud [Re: 340wedge] #63507
05/25/08 09:28 PM
05/25/08 09:28 PM
Kirkland, Washington
Pacnorthcuda Offline
Nothing will be "perfect" but good old Krylon Semi Flat will look very nice
Re: Asking for tips-Painting the plastic radiator shroud [Re: Pacnorthcuda] #63508
05/25/08 09:55 PM
05/25/08 09:55 PM
Mississauga, Canada
KARLN Offline
KARLN  Offline
Mississauga, Canada
or the SEM paint is very good too. Make sure you fog it.
B5 Challenger T/A
Re: Asking for tips-Painting the plastic radiator shrou [Re: KARLN] #63509
05/25/08 11:17 PM
05/25/08 11:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I would recommend using an adhesion promoter after a good cleaning and light scuffing.
Krylon might have a semi-gloss black intended for plastic; I know they have other colors.
Re: Asking for tips-Painting the plastic radiator shroud [Re: KARLN] #63510
05/25/08 11:41 PM
05/25/08 11:41 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
I used SEM paint (Landau Black) too. It turned out pretty good.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Asking for tips-Painting the plastic radiator shroud [Re: 69CoronetRT] #63511
05/26/08 12:32 PM
05/26/08 12:32 PM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
I had very good luck using SEM plastic bumper paint. I used in on the plastic shields for the fenders/doors (E-body). They turned out like brand new, and do not look painted at all.
I first glass beaded the parts using a very fine glass bead, then gave them 3 coats. This should work on your rad shroud too.
I also tested this on a junk part first, and the adhesion is very good. I flexed it back and forth many times, and no problems.
Re: Asking for tips-Painting the plastic radiator shroud [Re: Barnabas_Kriss] #63512
05/26/08 06:08 PM
05/26/08 06:08 PM
340wedge Offline OP
340wedge  Offline OP
Sounds like SEM is the answer, Thanks guys!
