Starter Date Code Question #634773
03/09/10 11:53 AM
03/09/10 11:53 AM
Columbus, Ohio
A4SixtyNineRR Offline OP
Columbus, Ohio
Hey guys, quick question for you. Would an original Chrysler starter for '69 be dated in days or weeks? The date code I am looking at is 0299 and I am not sure if that is the 29th day OR 29th week of '69. Buddies of mine have differing opinions as well. Anyone know for sure? Thanks!
Re: Starter Date Code Question [Re: A4SixtyNineRR] #634774
03/09/10 12:01 PM
03/09/10 12:01 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
There would only be three digits, not four. It is stamped on the barrel under the word CHRYSLER along with a seven digit part number. Three digits is indicative of the first two being the week of the year, and the last one being the year. Post a picture is you can.
Re: Starter Date Code Question [Re: m46rat] #634775
03/09/10 12:03 PM
03/09/10 12:03 PM
m46rat Offline
m46rat  Offline
Sorry, didn't notice the picture. It is the 29th week of 1969 which would be for a 1970 model year car. Part number is 2875 560. Does that date match your car?
Re: Starter Date Code Question [Re: m46rat] #634776
03/09/10 12:38 PM
03/09/10 12:38 PM
Columbus, Ohio
Columbus, Ohio
Sorry about that. You are correct that it is only 3 digits of 299. I've also read that the pinwheel on the side of the housing indicates the date as well. The year is stamped in the center of the circle and the month is indicated by the number of spokes that have dots in the middle of them?
Re: Starter Date Code Question [Re: A4SixtyNineRR] #634777
03/09/10 01:36 PM
03/09/10 01:36 PM
m46rat Offline
m46rat  Offline
Yup, that is correct. Does the case part of your starter have a date that matches the July, 1969 date on the barrel? Post a picture if you can.
Re: Starter Date Code Question [Re: m46rat] #634778
03/09/10 02:38 PM
03/09/10 02:38 PM
Columbus, Ohio
Columbus, Ohio
Here's the pinwheel on the housing. It looks as though it was stamped upside down b/c the part number is defintley for '69-70 and not a 1966.
Re: Starter Date Code Question [Re: A4SixtyNineRR] #634779
03/09/10 03:40 PM
03/09/10 03:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Usually there is a two digit number in the center of the pinwheel, it appears it is missing the "9".
............ but how is the "pinwheel" counted? What is the correct barrel number and nose casting number for our '60s & '70s musclecars?
Here are pics from a starter I have laying around.
nose casting #3755259 - vendor #05305 - pinwheel "sometime" in '74
Re: Starter Date Code Question [Re: 6bblgt] #634780
03/09/10 03:44 PM
03/09/10 03:44 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
barrel #3656650 date #312 (31st week of 1972)
