Re: Cast iron manifolds?
[Re: TrxR]
#634058
03/08/10 04:36 PM
03/08/10 04:36 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
That all depends on the application. Some manifolds work easily while others won't fit without major surgery.
[Re: TrxR]
#634060
03/08/10 08:05 PM
03/08/10 08:05 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Other than stainless headers, I don't think you could do better than cast manifolds.
[Re: DaytonaTurbo]
#634063
04/01/10 09:15 PM
04/01/10 09:15 PM
feets
Senior Management
Senior Management
Irving, TX
I dug out my cast iron manifolds for another look. I'd have to do some major surgery on the manifolds to fit. It would require moving the outlets up top. I simply don't think it's worth that kind of investment on my car.
[Re: TrxR]
#634065
04/02/10 03:43 AM
04/02/10 03:43 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
