Cast iron manifolds? #634056
03/08/10 01:37 PM
03/08/10 01:37 PM
New Brunswick, Canada
TrxR Offline OP
TrxR  Offline OP
I think I found a set of factory manifolds that would fit my application but was wondering how well you guys think they would hold up? Would they last , will I be able to keep them sealed? They wont be holding the wight of the turbo or anything like that.
Re: Cast iron manifolds? [Re: TrxR] #634057
03/08/10 01:42 PM
03/08/10 01:42 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
They will work quite fine. I used the stock slant 6 manifold without issue before I built a set of headers. There are a number of other guys using manifolds out there. They will chime in soon enough with their experience.
Re: Cast iron manifolds? [Re: TrxR] #634058
03/08/10 04:36 PM
03/08/10 04:36 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That all depends on the application. Some manifolds work easily while others won't fit without major surgery.
- Stu Harmon
Re: Cast iron manifolds? [Re: feets] #634059
03/08/10 04:50 PM
03/08/10 04:50 PM
TrxR Offline OP
TrxR  Offline OP
Im not that concerned about the fit as it will be in a truck with an engine plate. I was more asking about the longevity,strength and sealing to the head.
Re: Cast iron manifolds? [Re: TrxR] #634060
03/08/10 08:05 PM
03/08/10 08:05 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Other than stainless headers, I don't think you could do better than cast manifolds.
Re: Cast iron manifolds? [Re: TRENDZ] #634061
03/11/10 12:26 PM
03/11/10 12:26 PM
Tampa, Fl
valiantboy Offline
super gas
valiantboy  Offline
super gas
Tampa, Fl
id have to agree. thays what ill be useing in the van. either 340hp's or a set of newer magnum 2.5" units.
Re: Cast iron manifolds? [Re: valiantboy] #634062
03/31/10 03:18 PM
03/31/10 03:18 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I don't think anything seals to the head better than manifolds.
Re: Cast iron manifolds? [Re: DaytonaTurbo] #634063
04/01/10 09:15 PM
04/01/10 09:15 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I dug out my cast iron manifolds for another look. I'd have to do some major surgery on the manifolds to fit. It would require moving the outlets up top.
I simply don't think it's worth that kind of investment on my car.
- Stu Harmon
Re: Cast iron manifolds? [Re: feets] #634064
04/01/10 09:46 PM
04/01/10 09:46 PM
TrxR Offline OP
TrxR  Offline OP
Im just thinking that in a Dakota with an engine plate it might just work.
Re: Cast iron manifolds? [Re: TrxR] #634065
04/02/10 03:43 AM
04/02/10 03:43 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
They work fine for me.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
