newer mopar 2004 neon transmission problem,, maybe????? #631569
03/05/10 06:03 PM
03/05/10 06:03 PM
sandusky ohio
mopardiebold Offline OP
sandusky ohio
2004 neon with 89,000 miles, when i put it in drive it waits like 2to 3 seconds and then it moves, and sometimes it waites 2to3 seconds and it moves a little and then a second later it moves little faster, like it shifts 2xs,going not even 1mph, and sometimes it workes normal no waiting @ all,its really weird any info would be appreciated,, thanks paul
Re: newer mopar 2004 neon transmission problem,, maybe????? [Re: mopardiebold] #631570
03/05/10 06:12 PM
03/05/10 06:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
2 things you need to do, Both require a scanner
ck the range sensor selector to make sure it's actually making the transittion from park to rev/drive electrically.
2nd would be ck and make sure you don't have a loss of prime fault, meaning either extremely low on fluid or front pump issue.
All A604 based transmissions automatically apply the low/rev clutch as soon as it's started. That way all it has to do is apply either the underdrive clutch or rev clutch. but by description it sounds like a ft pump issue
Re: newer mopar 2004 neon transmission problem,, maybe????? [Re: gtx6970] #631571
03/05/10 07:55 PM
03/05/10 07:55 PM
sandusky ohio
sandusky ohio
ok thanks
