Page 5 of 11 1 2 3 4 5 6 7 10 11
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631085
03/30/10 07:35 AM
03/30/10 07:35 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
This is actually another thing that I wanted to get done before blasting. Also got a replacement oem radiator core support on ebay last week, mine is really bent up and even has some tears in it along with an added hole or 2, so I will remove and replace it before blasting as well, will post pics of that too.
`68 Road Runner "JUNKYARD DOG" `70 A66 FK5 Challenger, Rough project. `68 Coronet R/T Black & white 4 speed. `97 Dodge 1500 4X4, 228,000 miles and going strong!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631086
03/30/10 07:47 AM
03/30/10 07:47 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
I would never have imagined that I would replace as many parts as I have in this project. Still no regrets and still doing really well on the budget.
Also a huge learning experience that I would consider priceless. What parts will be original to the car?, here is a short list of major parts, roof, rear underseat floorpan, front frame rails, inner and outer rocker assemblies, inner fenders and k-frame with steering and suspension components.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631087
03/30/10 07:30 PM
03/30/10 07:30 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Worked on it again today for several hours, more grinding and welding, no pictures, TEDIOUS!!!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631088
03/31/10 10:34 PM
03/31/10 10:34 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Hey Matt, nobody will ever say that work is not time consuming after watching your progress Its looking good and if you dont get some body shop offers for a job after this I will be shocked You might want to try an E-body convert after your done with the RR Greg
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: G-Money1320] #631089
04/01/10 04:41 AM
04/01/10 04:41 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Thanks Greg, do you have a particular E body vert. in mind?.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631090
04/12/10 08:42 PM
04/12/10 08:42 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Have been working on it a lot lately decided to replace the whole cowl section before media blasting and a coat of primer. I took many precautions to make sure nothing moves when I free this part up. In the process I figured I would replace the radiator core support, because it was pretty beat up, which led to me remove the passenger inner fender because it had been removed at some point and not put back properly. One thing literally leads to another.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631091
04/12/10 08:47 PM
04/12/10 08:47 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
More!!!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631092
04/12/10 08:52 PM
04/12/10 08:52 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Still more!. I just found out I will be going out of town for business in 3 to 5 weeks for 3 weeks, so I am really trying to get it to the media blaster and in to my buddies body shop for primer before I go.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631093
04/12/10 08:53 PM
04/12/10 08:53 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
More!!!!!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631094
04/12/10 09:04 PM
04/12/10 09:04 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Tempted to have my buddy work on it while I'm away, but I really want to do all of the metal work on my first total resto myself. Man would it be nice to see the quarters on it when I got back though!. As of now the cowl is all but out, one more a-pillar to drill out.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631095
04/12/10 09:20 PM
04/12/10 09:20 PM
, PA
sleepyhead416 Offline
, PA
My project looks small compared to yours. Keep up the good work.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631096
04/13/10 10:32 AM
04/13/10 10:32 AM
MA
Mattyweb Offline
Mattyweb  Offline
MA
Matt, thanks for the pics. You are an inspiration. My 68RR is almost as bad as yours so you are motivating me with this post. Question for you: do you need the rear window corners if you are replacing the whole quarter? I'll be replacing my roof with a donor and using the AMD quarters and filler panel, will I still need to get those outer corner peices at the bottom of the window? My inner corners are not too bad so I'll repair those but the outer is so far gone I can't tell what I'll need.
Thanks!
Also, anyone have any suggestions on how to swap out the roof? I have been debating mostly on the front; wether to just cut strait through the pillar and but weld the new one on maybe with a few backing plates inside, or should I try to separate the seams at the top of the windshield? The back I just plan on separating the inner/outer skin at the seams at the top of the 1/4.
1968 Road Runner hardtop 440 4spd 2010 Ram 1500 Laramie 1992 Ramcharger
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: Mattyweb] #631097
04/13/10 11:11 AM
04/13/10 11:11 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Thanks!
Mattyweb, thanks for the props. Go back to my posts from March 10th, you will still need the little boomerang shaped corners when replacing the full quarters, unless yours are saveable. I know AMD offers a rear window corner repair kit which you would use if not replacing quarters.
There is a guy named Donny over at FBBO (For B-Bodies Only) another great site who has a thread in the resto forum following the rest on his GTX. His is torn down farther than mine, including the roof skin, maybe check it out and it might be of some help to you. Good luck.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631098
04/13/10 02:55 PM
04/13/10 02:55 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
The cowl is out, looks kind of scary, doesn't it?
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631099
04/13/10 02:56 PM
04/13/10 02:56 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Another!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631100
04/13/10 03:03 PM
04/13/10 03:03 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
BTW, HUGE precautions before I did this!!!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631101
04/13/10 09:03 PM
04/13/10 09:03 PM
MA
Mattyweb Offline
Mattyweb  Offline
MA
Matt, I checked out Donny's GTX build. That's another great resource, thanks!
Here's what I'm working with for a corner, so I don't think I have much I can save. I'll be careful though just in case. I think I can salvage the inner with a little bit of fab work.
That does look a little scary without the cowl on. Did you find alot of lead solder at the bottom of the roof pillars? I started picking at mine to plan out the roof swap and I'm finding alot of lead in there. Original or is that a repair made sometime in its life?
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: Mattyweb] #631102
04/14/10 06:48 AM
04/14/10 06:48 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Mattyweb, I can almost guarentee you will need the little boomerang shaped window sub-corners and you may need the parts below them as well. The part that attaches the sub-corner to the package tray, I'll repost the pic with the layers of parts that make up these corners. No repops for this one yet, so you may have to fab something up. I may have an extra set, but I won't know for a while.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631103
04/28/10 08:04 AM
04/28/10 08:04 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Since I decided to replace the cowl now, I had to do some more home spot sandblasting. In prep for any assembly work I have done so far, I clean and blast the joints to be welded and use a weld through primer and some POR 15. Also doing some repair work on the top of the passenger side rocker under the forward door jamb and prepping the replacement cowl section.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631104
04/28/10 08:06 AM
04/28/10 08:06 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Another 1.
