Page 4 of 11 1 2 3 4 5 6 10 11
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631065
03/12/10 07:59 AM
03/12/10 07:59 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
I found one more pic of my rear window corners "before", it doesn't get much worse than that!. There was almost nothing left of the filler panel, in fact someone had riveted aluminum coil stock(for siding)over the gaping holes.
`68 Road Runner "JUNKYARD DOG" `70 A66 FK5 Challenger, Rough project. `68 Coronet R/T Black & white 4 speed. `97 Dodge 1500 4X4, 228,000 miles and going strong!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631066
03/12/10 08:41 AM
03/12/10 08:41 AM
SD800 Offline
SD800  Offline
Most people would have parted that, you are a true insperation.
I'm currently working on my 69 RR and when that goes to the body guy I will start on my 68.I bought my 68 out of western Nebraska from a fellow Moparts member.It pretty solid with just the quarters have a little rust, it was originaly Gold with a White vinyl top and green interior
You'll have plenty of time to sleep when your dead, let's go
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: RareTA] #631067
03/12/10 09:31 AM
03/12/10 09:31 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Looks like it's coming along well. I sold my 68 LL1 Road Runner a year ago. It is going to be gorgeous when you are done.
My most favorite '68 Road Runner of all time.
Matt.. Great thing you're doing. Keep up the great work......
Troy
Houston Mopar Connection Club
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631068
03/12/10 09:59 PM
03/12/10 09:59 PM
Frozen Northeast
P
Primer King Offline
Primer King  Offline
P
Frozen Northeast
Absolutely great work going on here! I took the "easy road" with my '65 and decided to just go hacked AWB with it; instead of the higher road that you have taken with replacing large pieces of the structure as Ma MoPar intended them to be. My hat is off to you for going thru all the work that you have (and will!) by yourself. Places like MCR have nothing on you! Keep it up!
You'll know that car better than the assemblyline guys who built it by the time you're done. Only original once? Well, ya, maybe. Nobody knows any original cars even 1/4 as well as you'll know that RR when you're done.
www.primerking.com : the place for anything that isn't shiny
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: Primer King] #631069
03/13/10 07:46 AM
03/13/10 07:46 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Thanks again for the positive feedback, I'm honored by your comments and it is also a great confidence booster.
I had some rust to contend with at the bottoms of the rear doorjambs as well. With as far as the car is torn apart at this point, I did not want to replace the entire jambs, so I found some nice, solid oem pieces on ebay for a fraction of the cost of the AMDs and cut out the patches that I needed.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631070
03/13/10 07:47 AM
03/13/10 07:47 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
That was the passenger side, here is what the drivers side looked like.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631071
03/13/10 07:57 AM
03/13/10 07:57 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
After on the passenger side, still need to smooth it out a bit and add a little more metal, this one was not perfect but was still in better shape than what was there.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631072
03/13/10 08:01 AM
03/13/10 08:01 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
After on the driver side and again still need to smooth it out a little more before I send it off to the media blaster. That is going to be this weekends job, to grind and dress all of the plug welds and the few stitch welds I've done to date.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631073
03/13/10 08:21 AM
03/13/10 08:21 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Good to see another 68 being saved. I've been slowly parting this one, but was hoping someone would want it for a cheap starter project. Doesn't seem like it will happen so most likely it will be crushed once fully parted.
If you need anything, but sheetmetal, PM me
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631074
03/13/10 09:42 PM
03/13/10 09:42 PM
Iowa - a member of the rustbel...
Birdturd Offline
Birdturd  Offline
Matt, thanks for the pics I havent tackled this type of work before so seeing the examples helps
-Josh
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: Birdturd] #631075
03/22/10 06:10 AM
03/22/10 06:10 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Got some more acomplished this past week, the pics might look a little redundent because I have basically welded in all of the parts that I have had test fit. All of the structural parts that come down from the roof to the tops of the wheelhouses, the trunk hinge mounting brackets and the package tray are now welded in. Still have a little welding left on the package tray and then a bunch of grinding before it is off to the media blaster.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: Birdturd] #631076
03/22/10 06:15 AM
03/22/10 06:15 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
I figure after next weekend I will be ready to load it up and send it over to the media blaster and then off to my buddies body shop for a coat of primer before I start installing all of the outer sheet metal.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631077
03/22/10 06:18 AM
03/22/10 06:18 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
More pics.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631078
03/22/10 06:19 AM
03/22/10 06:19 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
One more.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631079
03/22/10 02:30 PM
03/22/10 02:30 PM
RI Deep in the rust belt
chargervert Online content
chargervert  Online Content
Matt,Dry fit your rear window and window moldings,before you paint the car,some minor modifications are necessary to insure perfect fitment. Use rubber shims the thickness of the window ribbon,to space the glass the correct distance from the window channel. The channel may require some cutting and rewelding,or some hammer shaping. Install all your molding retaining clips in the proper locations. You may spend the better part of a day doing this,but it's better to find out now,than after it's painted.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: chargervert] #631080
03/22/10 02:57 PM
03/22/10 02:57 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Boy, you sure move fast.
I can't afford this. mark
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: chargervert] #631081
03/23/10 06:41 AM
03/23/10 06:41 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Chargervert, thanks for the info, ironically, a buddy of mine owns a body shop and they just did a restoration on a Chebby. Sent it off to another location to get the glass and some other things installed on it and when they got it back and tried to put the trim on the rear window, they found that the proper spacers were not used and the trim stood off from the glass by a quarter inch. Out comes the new glass, risking damage to the fresh paint and trim, what a waste. You can gaurentee I will be paying close attension to any reassembly that I will not be doing myself.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: a12superbee] #631082
03/23/10 06:47 AM
03/23/10 06:47 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Thanks, but keep in mind this project started 3 years ago, I feel I'm a little behind schedule, but this s#%t ain't cheap and work is constantly getting in the way!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631083
03/30/10 06:28 AM
03/30/10 06:28 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Still trying to get it ready for media blasting, if there is anybody out there that thinks this work is not really time consuming, I'm here to tell you it is. Finished welding in all the parts around the package tray and began the tedious task of grinding down all of the plug welds that I have done since I started putting it back together. You definitely have to put yourself in the "zone" for this process! . In order to break up that minotony I finished the repair on the rear tailpanel cross member and here is how that looked.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631084
03/30/10 06:31 AM
03/30/10 06:31 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
The rear clip I got from NM had been dragged without suspension on it and that piece got messed up as a result, so I cut it out. The piece that I used to replace it is actually the oirginal one to the car
