Page 2 of 11 1 2 3 4 10 11
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: A12] #631025
03/06/10 07:17 AM
03/06/10 07:17 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
I'll be watchin, Mines a 68 w/ the decor pkg but its B5.
my '68 rr with decor and FF1 mist green metallic
Love that FF1, sweet ride!, can't go wrong with B5 either.
Mine didn't need both framerails but since I had that whole section sitting there like that, all preassembled, I thought it would be a shame to take it all apart when I could just do a bunch of prepwork on it and install it as a unit. So that is what I set out to do. Started to remove the parts from the "DOG" one by one, which gave me a good working knowledge of how it was assembled. Before I started dissassembly I mounted the car on that steel rack I fabbed up and transferred a bunch of marks and measurements down to it so that I would have reference points on reassembly. The rack also keeps the car really rigid and in its original position in relation to a centerline.
Keep in mind I have never done anything like this before so if anything I am being to cautious not to F anything up.
`68 Road Runner "JUNKYARD DOG" `70 A66 FK5 Challenger, Rough project. `68 Coronet R/T Black & white 4 speed. `97 Dodge 1500 4X4, 228,000 miles and going strong!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: a12superbee] #631026
03/06/10 07:55 AM
03/06/10 07:55 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Most excellent.
<click favorite thread button>
How did you peel the paint off and not go straight to the bone?
I'd love to know whats under the plasti-coat on my car.
I used an environementally friendly aircraft stripper that I bought from a local auto paint store. Unfortunately it messed up the lettering on the quarters, both sides. I was able to figure out the important part of what it said though, which further helped me in tracing the cars history. Here it is with all of the parts removed.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: JS29R0B] #631027
03/06/10 08:11 AM
03/06/10 08:11 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
What motor was it originally?
It would be cool to get a small decal made of the dog and stick it on the back window for a little history.
Thanks, that is a great idea!. I figure those doors that came on the car really weren't worth reusing but will always have a spot on the wall in my shop.
This is the doner section almost ready for installation. I cut all of the stuff off that I didn't need and cleaned it up really well and used weld through primer in all of the joints.
I was able to sell off parts from that doner piece and even sold a few things that I removed from my car to further offset the cost of the parts. In all I ended up spending about $600.00 for a rust-free lower rear clip. I would have spent 3K with AMD to get those parts and they still would have been a mind-numbing pile of parts in need of assembly.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631028
03/06/10 08:17 AM
03/06/10 08:17 AM
Buford, GA
I_bleed_MOPAR Online content
I_bleed_MOPAR  Online Content
Buford, GA
You truly are ambitious, my friend, as well as talented. I know a couple of folks capable of what you are doing but I'm not one of them. Keep us posted- that will be a beautiful car when you're done.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: I_bleed_MOPAR] #631029
03/06/10 08:49 AM
03/06/10 08:49 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Tim
Thanks brother!.
Next was to rig up the doner part to get it in position.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631030
03/06/10 08:57 AM
03/06/10 08:57 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Once I got it floating there i just moved the car to it, attached some ratchet straps to the frame rails and the other end to the front of the steel jig and pulled it the final 1/2" into place. The chain fall made for the perfect up and down fine tune adjustment until the whole thing was in the exact spot that the old parts came from and then it was just a matter of plug welding. Not including the fab of the jig, the whole process took about 5 or 6 days.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631031
03/06/10 08:59 AM
03/06/10 08:59 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
More to come later, time to get out to the shop and continue!.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631032
03/06/10 10:10 AM
03/06/10 10:10 AM
N. Dak.
RareTA Offline
super street
RareTA  Offline
super street
N. Dak.
[quote
Wow, rareT/A that car is beautiful!, must have been hard to sell for you. Did you sell to make room for another one?.
Yes. We only have room for 3 play cars so it got sold to make room for the 09 R/T. To be honest using the cash from the RR we only needed $2500 of our own to pay cash for the R/T.
'09 Challenger R/T '70 Challenger T/A 340 6Pak and Auto I was born with nothing and I still have most of it left!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: RareTA] #631033
03/07/10 08:41 AM
03/07/10 08:41 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Here it is with the new rear frame rail section welded in. Once I had all the plug welds done I disconnected from the chain fall and checked all my measurements and reference points, as I had been doing all the way through the process, OFTEN!. Everything lined up perfect!.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631034
03/07/10 08:43 AM
03/07/10 08:43 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
From the bottom.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631035
03/07/10 08:45 AM
03/07/10 08:45 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
More!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631036
03/07/10 08:51 AM
03/07/10 08:51 AM
mpls,MN
dodgedakotaman Offline
mpls,MN
Hi, Just curious why you didn't media blast the new section before welding it in?
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631037
03/07/10 09:05 AM
03/07/10 09:05 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
After the new sectin was welded in I removed the rest of the old quarters that I had left in for further reference points and started to focus on all of the rot from the leaky lower rear window corners. More parts not being repoped yet so more doner hunting I went and with great success. Another Craigslist ad led me to a `68 coronet parts car that someone else local had brought up from GA, took what he needed off of it and sold the rest to me for almost nothing. It had the solid understructure parts that come down to the top of the wheelhouses as well as a nice package tray and trunk hinge brackets and window corner parts, as well as a bunch of other parts that I will put to good use as I make my way forward on this car. I have already sold off a bunch of parts I didn't need from that deal and ended up with over a thousand bucks back in my pocket. That is like getting paid to buy parts, if that makes any sense at all. With the money I made back on that deal I purchased a pair of full quarters and a pair of trunk floor extensions from AMD. The quarters were scratch and dents from a local dealer that really took only minor hammer and dolly work to straighten and they were less than 50 cents on the dollar. At this point I am well under budget!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: dodgedakotaman] #631038
03/07/10 09:11 AM
03/07/10 09:11 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Good?.
I figured it would be more cost affective to have the whole car media blasted and then primed after it was installed but before all of the new outer sheet metal went on. I sand blasted and primed all of the connection points before I installed it.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631039
03/07/10 09:16 AM
03/07/10 09:16 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Here it is after I removed the rest of the rusty parts from the back half, did some spot sand blasting and priming, now ready for more assembly.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631040
03/07/10 09:18 AM
03/07/10 09:18 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Another shot.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631041
03/07/10 09:24 AM
03/07/10 09:24 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
At this point I am going to screw and clamp everything together including the new quarters so that I can bolt the trunk lid on and triple check that all is good up to this point before I take it back apart and get the whole understructure media blasted and primed.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631042
03/07/10 09:25 AM
03/07/10 09:25 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
More.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631043
03/07/10 09:28 AM
03/07/10 09:28 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
With some of the money I made back on the extra parts I sold I was able to afford more AMD metal instead of fixing some of the old stuff. I'm toatally excited at this point!!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631044
03/07/10 09:35 AM
03/07/10 09:35 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Another shot, it is starting to look like a car again, even if it is just temporary.
