What throttle cable? 440 w/ Performer RPM #629622
03/03/10 12:55 PM
03/03/10 12:55 PM
Westphalia, Meeeeeshigan
MIRADAMANia Offline OP
Will I need a longer accelerator cable for my 71 Charger to 440 w/ Edelbrock Performer RPM? If so has anybody found one that will work?
Re: What throttle cable? 440 w/ Performer RPM [Re: MIRADAMANia] #629623
03/03/10 01:42 PM
03/03/10 01:42 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I have Lokars on both the BB 71 and SB 72 chargers. Team G intake on the BB and RPM on the SB.
Re: What throttle cable? 440 w/ Performer RPM [Re: WILD BILL] #629624
03/03/10 01:45 PM
03/03/10 01:45 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
You can use a /6 or truck... They are the longest factory...
Re: What throttle cable? 440 w/ Performer RPM [Re: MIRADAMANia] #629625
03/03/10 04:08 PM
03/03/10 04:08 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Lokar -> Bracket, throttle and throttle pressure aka: kick down. All the cable lengths are custom fit and easy to install.
Re: What throttle cable? 440 w/ Performer RPM [Re: MIRADAMANia] #629626
03/03/10 04:35 PM
03/03/10 04:35 PM
AndyF Offline
AndyF  Offline
Longer cables are probably still available from Dodge dealers or try suppliers like Mancini. I always use the factory type cables. Mancini or Hughes also have taller throttle brackets to work with the taller intake manifolds.
Re: What throttle cable? 440 w/ Performer RPM [Re: AndyF] #629627
03/03/10 04:40 PM
03/03/10 04:40 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
I used the stock cable on my 68 Dart. Originally a 273 car.
codfish
Re: What throttle cable? 440 w/ Performer RPM [Re: codfish] #629628
03/04/10 01:06 AM
03/04/10 01:06 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My intake is the Holley Street Dominator with a 1" spacer but I also use the Lokar cabe and it works great. Very easy to install and you make the cable the lenth you need. Ron
Re: What throttle cable? 440 w/ Performer RPM [Re: 383man] #629629
03/04/10 03:05 PM
03/04/10 03:05 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I dunno I HATED my lokar. it never seemed to be adjusted right. I yanked it off at the track and used an old /6 cable I found and it worked perfect.
Coming soon!!!!
Re: What throttle cable? 440 w/ Performer RPM [Re: Mr.Yuck] #629630
03/06/10 09:59 AM
03/06/10 09:59 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
I had exactly the same problem. It would rotate on the carb stud. I tossed it and bought one of AR's brackets it works great.
1974 Roadrunner
1967 Charger
