K-member repair
#629416
03/03/10 01:12 AM
03/03/10 01:12 AM
Posts: 183 Canada
Mofopar
Canada
Re: K-member repair
[Re: Mofopar]
#629420
03/03/10 05:05 PM
03/03/10 05:05 PM
Posts: 21,231 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
You might be able to pull the dents by welding a bolt to it and then using a slide hammer to tug them out. I had a couple sharp dents on mine so I cut out the damaged area with a holesaw bit, hammered the metal flat, and then welded it back in place. Came out pretty decent. You can fill deep gouges by welding over them and then carefully grinding or filing them flush.
Another way to get at the dents on the bottom is to drill out holes on the top and them weld them shut once your done beating it back into shape.
Re: K-member repair
[Re: Neil]
#629421
03/03/10 06:01 PM
03/03/10 06:01 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
blast the K,and see if its savable,and do a QUALITY weld repair if it is. if not i would replace it in a second...it kinda holds the front of the car together,and is really important,eventhough they are kinda cheap,a good one is priceless,imho. with all the potholes here in mich/ind,i would want a good one,for sure.
Re: K-member repair
[Re: imfixinmopars426]
#629422
03/04/10 01:02 AM
03/04/10 01:02 AM
Posts: 183 Canada
Mofopar
Canada
I like the slide hammer idea and opening up a hole or 2 on the top side. Its pretty solid except for one small spot that's rusted through. We'll see more after its cleaned up. Thanks for the replies guys, this place is the best . For a guy like me that got started later in life and with few buds to hang with that are mechanics, its so cool to have a place to visit where guys openly share their knowledge and expertise. Much appreciated!
Re: K-member repair
[Re: Mofopar]
#629424
03/09/10 12:02 AM
03/09/10 12:02 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I dont think they were continous welded. but, If it was my part, I would weld it completely and add a skid plate to protect the pan...
