Re: indexing plugs
[Re: deaks]
#628157
03/01/10 07:50 PM
03/01/10 07:50 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
I am fitting my 76cc RPM heads to a new short block with 12.5.1 venolia domes, will i need to index the plugs and where can i buy the washers to do it. Mick
Mick, every motor is different, I'm sure there is no way to say absolutely yes or absolutely no! Take one of the plugs you want to race with and install it(with the head off) so the bend of the ground strap is pointed striaght down so it will hit the piston dome. Install the head with the gasket your going to use ( make sure and install the rod and piston) and then rotate the motor slowly from 20 BTDC to 20 degrees ATDC, you may want to install some clay on the sparkplug end also. check the results and go from there I use to thank that there was around .01 to .02 ET increase by indexing all eight plugs in my M.W stocker there wasn't , it was the weather changing making the ET changes All the other racers where seeing the same increases without opening there hoods Are you using a projected gap plug or a non projected tip plug? the last thing is are the Venolia pistons tops designed for the Eddy heads only or are they a generic shelf piston for 440 motors with a standard pop up dome?
Re: indexing plugs
[Re: deaks]
#628160
03/01/10 09:05 PM
03/01/10 09:05 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Hi Mick. We don't do it anymore even in the SS/AH motors. Big MSD spark doesn't care. Kinda like cool cans,faded away.
The little old lady from Pasadena is back!
Re: indexing plugs
[Re: Barnstorm]
#628162
03/02/10 04:45 PM
03/02/10 04:45 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Exactly. Indexing is a waste of time unless it for clearance.
Re: indexing plugs
[Re: BobR]
#628163
03/02/10 05:18 PM
03/02/10 05:18 PM
Barnstorm
Minnesota
With the stock 60's and 70's standard coil and points system, there may have been some benefit. However with most ignition systems like MSD and the like, they put out so much spark that turning the plug here or there doesn't seem to make a differance in engine performance.
Re: indexing plugs
[Re: deaks]
#628167
03/02/10 06:29 PM
03/02/10 06:29 PM
Posts: 1,200 UK
602heavy
UK
Mick , you're question was answered by Cab , you need check the plug in the head with the head off , no one can tell you how much those plugs need to be spaced with washers , maybe they don't? , i would.nt take a chance on somebody else telling me how they did it as all motors are different , personally i would'nt use the projected type plugs with that compression ratio , the non projected type plug will gain you more clearance (NGK BCR)
Try Sumit racing for those spacers.
