SB WINDAGE TRAY #626496
02/28/10 04:57 AM
02/28/10 04:57 AM
Queensland Australia
moparmacka Offline OP
Another thing that has been bothering me......is there any significant advantage in having a Milodon windage tray with a 4.000" stroke crank? Considering the outboard louvres have to be modified to clear 'H' beam rods and restricting oil return. Almost a 1/3 of the opening have been closed up for clearence.
Again, just after opinions
Macka
Re: SB WINDAGE TRAY [Re: moparmacka] #626497
02/28/10 08:15 AM
02/28/10 08:15 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Tried one with the stud maincap setup .PIA
we quit running one .
don't think too much to gain .
DR
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: SB WINDAGE TRAY [Re: moparmacka] #626498
02/28/10 03:14 PM
02/28/10 03:14 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Again, just after opinionS
Macka
Re: SB WINDAGE TRAY [Re: 572B1] #626499
02/28/10 04:43 PM
02/28/10 04:43 PM
408Dust Offline
408Dust  Offline
Do your self a favor and list it on E-bag.
Re: SB WINDAGE TRAY [Re: 408Dust] #626500
02/28/10 08:17 PM
02/28/10 08:17 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Not only does not not help it may actually hurt. Very few guys in the know use a windage tray on a SB.
Re: SB WINDAGE TRAY [Re: BobR] #626501
02/28/10 09:37 PM
02/28/10 09:37 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I read that horsepower dropped significantly with a tray and a 4 " arm.
The book was " How to build big inch small block MoPars " and the number IIRC was around 24 ponies picked up without a tray.
I do not know if that holds true for a scraper as well.
I think a scraper on one side and the sump far enough below the rotating assy. would be the hot set up.
Re: SB WINDAGE TRAY [Re: tubtar] #626502
02/28/10 11:49 PM
02/28/10 11:49 PM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
did they specify the reasoning behind the loss with the tray/vs no tray
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: SB WINDAGE TRAY [Re: Stroker Scamp] #626503
03/01/10 03:00 AM
03/01/10 03:00 AM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
Dang, Mine still has the stock windage tray!I just had to put a washer under each mounting bolt, no other mods or clearancing...none to the block either. Maybe I need to yank the pan and take it off! Wish I would have tried that when I had it on the dyno!
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: SB WINDAGE TRAY [Re: Stroker Scamp] #626504
03/01/10 09:58 AM
03/01/10 09:58 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The tray keeps the oil from draining back to the pan and actually exacerbates the oil/crank issue.
Re: SB WINDAGE TRAY [Re: BobR] #626505
03/01/10 11:09 AM
03/01/10 11:09 AM
Casa Grande,Arizona
DennisJ Offline
super street
DennisJ  Offline
super street
Casa Grande,Arizona
Back in the mid 1970s, Direct Connection had performance seminars in several cities.I went to the Seattle Wa. seminars for a few years.
The consensus was to not run a windage tray in a small block.
I don't remember the explanation that was given.
Dennis Jokela
I started out with nothing,and I still have most of it.
Re: SB WINDAGE TRAY [Re: DennisJ] #626506
03/01/10 03:16 PM
03/01/10 03:16 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We booted the tray in our 4" stroker, 6 qt rear sump pan, with the tray we were makin oil in the evac, no oil with out the tray, could not tell if there was any power change
Re: SB WINDAGE TRAY [Re: BobR] #626507
03/01/10 10:32 PM
03/01/10 10:32 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Yep.
And this is simply what I have read.......no practical experience with it.
But it sounded good on paper.
Stock SB WINDAGE TRAY [Re: tubtar] #626508
03/02/10 07:56 AM
03/02/10 07:56 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
The stock 340 tray doesn't have enough openings to be effective. I'm pretty sure that's in the DC tech bulletins compiled in the Engine 'Speed Secrets' book. They say add more louvres if your going to use it. I beleive the reason is as already stated - it does the opposite of its purpose, holds too much oil next to the crank.
The milidon one in your photo looks like it's louvred in toward the crank. That's opposite of the Chrysler design. I'm sure Milidon had their reasons, but it doesn't look like it would drain quickly. If I was going to experiment with it, I'd check clearance, and then add at least twice the number of louveres inward if there is room. If its too close to the crank; open it the other way or convert it to a screen type.
edit: Uh, nevermind the first suggestion to check clearence. You've got proof enough that inward doesn't work for your crank.
Re: SB WINDAGE TRAY [Re: moparmacka] #626509
03/02/10 08:15 AM
03/02/10 08:15 AM
Az
Crizila Offline
Crizila  Offline
Az
If you have a Milodon catalog, you will see that they recommend trays with certain pans, while others, they don't. When I put an 8 qt Milodon pan on my 408, they recommended a tray with the pan I bought, so I used it. I didn't have any clearance problems ( I beam rods ). Don't think mashing the louvers closed is a very good idea though.
Fastest 300
Re: SB WINDAGE TRAY [Re: Stroker Scamp] #626510
03/05/10 10:44 PM
03/05/10 10:44 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
What that book said is that tray sold by MP was designed for the 3.31 stroke (318/340) motors and it fits the 360, but the crankcase pressure is actually INCREASED as "does not work as well" in this application, therefore not recommended. Further it will not fit with a 4.00" crank as there isn't enough clearance to the rods and crank.
A sidebar in the Oiling chapter says that a tray was tested on a 408 motor using a STOCK 360 pan and the HP loss "was about" 42 HP. That seems like a ALOT of power loss.
Now, I eyeballed the MP tray in a 416 I am doing and although I didn't take any measurements the crank and rods are VERY close...so close that I don't think I want to try it. I'd love to evaluate on the dyno, but don't have that kind of time.
As much as that book promotes MP parts, (there was no mention of any other brand of tray) seems like a pretty honest evaluation and recommendation.
I dusted this thread off and chimed in, hoping to hear more from the small block stroker crowd especially. To tray or not to tray???
Re: SB WINDAGE TRAY [Re: cudadoug] #626511
03/06/10 04:29 AM
03/06/10 04:29 AM
I agree 42 HP loss seems to be significant. This is why I originally created this post to gain opinions from personal experiences.
Re: SB WINDAGE TRAY [Re: moparmacka] #626512
03/06/10 08:39 AM
03/06/10 08:39 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I've heard about drainback issues so I decided to fix that problem.
I cut large windows in the stock tray in-line with the rods and welded directional screen over them.
Can't quantify any benefit but the motor ran great and it was fun to make.
This was a 408 with IJ scrapers. Notice I had to trim the sides of the tray down for rod clearance.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: SB WINDAGE TRAY [Re: moparmacka] #626513
03/06/10 08:54 AM
03/06/10 08:54 AM
Canada
lenweiler Offline
lenweiler  Offline
Canada
I'm using a crank scrapper...........
Damn! I dropped my change.............
Re: SB WINDAGE TRAY [Re: CJK440] #626514
03/06/10 09:05 AM
03/06/10 09:05 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
cjk440 has a good idea that looks like it would work and with a scaper should be a good combo.
they make those screens for chevy's, why not mopars?
Re: SB WINDAGE TRAY [Re: CJK440] #626515
03/06/10 06:10 PM
03/06/10 06:10 PM
Nice work! Ever thought of selling them!!!!! Is that a scraper I see, if so where did you get that?
Macka
