Re: SB WINDAGE TRAY
[Re: moparmacka]
#626497
02/28/10 09:15 AM
02/28/10 09:15 AM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
Tried one with the stud maincap setup .PIA we quit running one . don't think too much to gain . DR
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
Re: SB WINDAGE TRAY
[Re: moparmacka]
#626498
02/28/10 04:14 PM
02/28/10 04:14 PM
Posts: 855 Brisbane Australia
572B1
Brisbane Australia
Another thing that has been bothering me......is there any significant advantage in having a Milodon windage tray with a 4.000" stroke crank? Considering the outboard louvres have to be modified to clear 'H' beam rods and restricting oil return. Almost a 1/3 of the opening have been closed up for clearence.
Again, just after opinionS
Macka
Re: SB WINDAGE TRAY
[Re: 408Dust]
#626500
02/28/10 09:17 PM
02/28/10 09:17 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Do your self a favor and list it on E-bag.
Not only does not not help it may actually hurt. Very few guys in the know use a windage tray on a SB.
Re: SB WINDAGE TRAY
[Re: Stroker Scamp]
#626504
03/01/10 10:58 AM
03/01/10 10:58 AM
BobR
Left Coast
I read that horsepower dropped significantly with a tray and a 4 " arm. The book was " How to build big inch small block MoPars " and the number IIRC was around 24 ponies picked up without a tray. I do not know if that holds true for a scraper as well. I think a scraper on one side and the sump far enough below the rotating assy. would be the hot set up.
did they specify the reasoning behind the loss with the tray/vs no tray
The tray keeps the oil from draining back to the pan and actually exacerbates the oil/crank issue.
Re: SB WINDAGE TRAY
[Re: BobR]
#626505
03/01/10 12:09 PM
03/01/10 12:09 PM
Posts: 302 Casa Grande,Arizona
DennisJ
super street
super street
Casa Grande,Arizona
Back in the mid 1970s, Direct Connection had performance seminars in several cities.I went to the Seattle Wa. seminars for a few years.
The consensus was to not run a windage tray in a small block.
I don't remember the explanation that was given.
Dennis Jokela
I started out with nothing,and I still have most of it.
Re: SB WINDAGE TRAY
[Re: BobR]
#626507
03/01/10 11:32 PM
03/01/10 11:32 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Yep. And this is simply what I have read.......no practical experience with it. But it sounded good on paper.
Stock SB WINDAGE TRAY
[Re: tubtar]
#626508
03/02/10 08:56 AM
03/02/10 08:56 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
The stock 340 tray doesn't have enough openings to be effective. I'm pretty sure that's in the DC tech bulletins compiled in the Engine 'Speed Secrets' book. They say add more louvres if your going to use it. I beleive the reason is as already stated - it does the opposite of its purpose, holds too much oil next to the crank. The milidon one in your photo looks like it's louvred in toward the crank. That's opposite of the Chrysler design. I'm sure Milidon had their reasons, but it doesn't look like it would drain quickly. If I was going to experiment with it, I'd check clearance, and then add at least twice the number of louveres inward if there is room. If its too close to the crank; open it the other way or convert it to a screen type. edit: Uh, nevermind the first suggestion to check clearence. You've got proof enough that inward doesn't work for your crank.
Re: SB WINDAGE TRAY
[Re: moparmacka]
#626509
03/02/10 09:15 AM
03/02/10 09:15 AM
Posts: 7,506 Az
Crizila
Az
If you have a Milodon catalog, you will see that they recommend trays with certain pans, while others, they don't. When I put an 8 qt Milodon pan on my 408, they recommended a tray with the pan I bought, so I used it. I didn't have any clearance problems ( I beam rods ). Don't think mashing the louvers closed is a very good idea though.
Fastest 300
Re: SB WINDAGE TRAY
[Re: Stroker Scamp]
#626510
03/05/10 11:44 PM
03/05/10 11:44 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
What that book said is that tray sold by MP was designed for the 3.31 stroke (318/340) motors and it fits the 360, but the crankcase pressure is actually INCREASED as "does not work as well" in this application, therefore not recommended. Further it will not fit with a 4.00" crank as there isn't enough clearance to the rods and crank.
A sidebar in the Oiling chapter says that a tray was tested on a 408 motor using a STOCK 360 pan and the HP loss "was about" 42 HP. That seems like a ALOT of power loss.
Now, I eyeballed the MP tray in a 416 I am doing and although I didn't take any measurements the crank and rods are VERY close...so close that I don't think I want to try it. I'd love to evaluate on the dyno, but don't have that kind of time.
As much as that book promotes MP parts, (there was no mention of any other brand of tray) seems like a pretty honest evaluation and recommendation.
I dusted this thread off and chimed in, hoping to hear more from the small block stroker crowd especially. To tray or not to tray???
Re: SB WINDAGE TRAY
[Re: cudadoug]
#626511
03/06/10 05:29 AM
03/06/10 05:29 AM
Posts: 370 Queensland Australia
moparmacka
I agree 42 HP loss seems to be significant. This is why I originally created this post to gain opinions from personal experiences.
Re: SB WINDAGE TRAY
[Re: moparmacka]
#626512
03/06/10 09:39 AM
03/06/10 09:39 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I've heard about drainback issues so I decided to fix that problem.
I cut large windows in the stock tray in-line with the rods and welded directional screen over them.
Can't quantify any benefit but the motor ran great and it was fun to make.
This was a 408 with IJ scrapers. Notice I had to trim the sides of the tray down for rod clearance.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: SB WINDAGE TRAY
[Re: moparmacka]
#626513
03/06/10 09:54 AM
03/06/10 09:54 AM
Posts: 259 Canada
lenweiler
Canada
I'm using a crank scrapper...........
Damn! I dropped my change.............
