Re: Hot off the dyno!!!!!!
[Re: LITEMUP]
#625226
02/27/10 12:08 PM
02/27/10 12:08 PM
Posts: 1,880 USA
Ron Silva
USA
You did good. I will never build another good motor without TI Valves. Another confirmation of Bullet Cams abilities.
SRT DEMON ONE SEAT
[Re: mr. 63plymouth]
#625228
02/27/10 12:30 PM
02/27/10 12:30 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Ya these are the headers I run in the car,thru full exhaust,best last year was [Email]9.52@142.82[/Email],at the time the engine made 741hp and 632torque on a older junkier dyno.I was really happy that the engine made what it did on this superflow!!!!!!!
That's way stronger than I'd have guessed. Race weight must be 3300 lbs.
[Re: MegaDart]
#625230
02/27/10 01:16 PM
02/27/10 01:16 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
gee, I guess no one here told you that's impossible !
i think he's asking for it by not sharing any specs on the combo.."750cfm. pump gas, hot cam, stroked" thats not much info to go on. I think a big block with heads that flow around 350 cfm would be hard pressed to make that kind of power on pump gas and a 750 cfm carb. Now if it had a 1050 dom and big roller around .800 lift and hi compression it would be understandable.
#625236
02/27/10 04:33 PM
02/27/10 04:33 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
ty valves were about 2500.00
Ohhhh, it's all comming back to me know, I didn't want to take out a lean on my house to buy them for my little stroker so I went with stainless instead
Excuse my ignorance, I know they weigh less, but what are the advantages in terms of benifits going to TI valves?
[Re: dc426]
#625239
02/27/10 05:03 PM
02/27/10 05:03 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
details!
I bet that electric water pump has alot to do with it. mike
#625242
02/27/10 06:15 PM
02/27/10 06:15 PM
Posts: 3,639 Oakland, MI
dizuster
Oakland, MI
Say what you will about B.S. but 9.50@143 is stout no matter what # the dyno said. If the weight is anything in the ball park of normal, I'm impressed...
