Re: Header evac tubes- how do they compare to vac pumps
[Re: 72demon416]
#624335
02/26/10 07:57 PM
02/26/10 07:57 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Topside- what is this electric GM pump off of? Any pictures of it?
![](/ubbthreads/images/graemlins/popcrn.gif)
Re: Header evac tubes- how do they compare to vac pumps?
[Re: emarine01]
#624337
02/26/10 08:09 PM
02/26/10 08:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hey Mr P, ya got a pic of your evac with the e vac tube square with the header tubes, we found the most vac 5.5" that way
I think I have a pic at home but I'm not home, you might have a little better sealing rings or a less accurate gauge but its still close to my findings ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#624338
02/26/10 09:02 PM
02/26/10 09:02 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
I know some SS/AH guys are pulling vac thru the fuel pump plate. Good "quiet" part of the motor. No valve cover hoses.
The little old lady from Pasadena is back!
[Re: 72demon416]
#624340
02/26/10 09:59 PM
02/26/10 09:59 PM
Posts: 2,119 sc
tjmarcus1
sc
thanks Raff, It looks like it's almost pointless to run a header evac system when running a exhaust system. the good part is you just saved me some time and money
didn't i say that?
[Re: tjmarcus1]
#624342
02/26/10 10:16 PM
02/26/10 10:16 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
didn't i say that?
Yes you did, thank you for your input! Actually- thanks to all contributors!
[Re: tjmarcus1]
#624345
02/27/10 08:29 AM
02/27/10 08:29 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Good thread.... Question: 1) WHERE do you mount the fitting on the header ? ( is there a measurement to use,,certain distance down the header ? any tips/tricks/troubles/ people have had installing them) ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) The instructions i have say on the TOP surface of the header, just beyond the TRANSITION area. 2) NO MORE POP OFF BREATHERS ? ( this is what i have now,,Moroso sells a "screw" on type deal,,,would that be ok ? ) ![](/ubbthreads/images/graemlins/scope.gif) 3) BAFFLES ? (just for the inside of the valve cover?) ![](/ubbthreads/images/graemlins/shruggy.gif) 4) HOSE TYPE (what are you guys using ?,,,is there a particular type recomended?) ![](/ubbthreads/images/graemlins/whistling.gif) I have the motor out of the car,,,so the headers can be worked on,,,, ![](/ubbthreads/images/graemlins/sawzall-smiley.gif) I have the Mr Gasket Evac kit ( sitting on the shelf ),,, Might be a good time to install them.... thanks. DOUG............ Moroso sells these,,,which i was thinking of getting,,, Just noticed they are about $50 EACH !! (yikes) they are the screw in style,,, i have seen some other styles that look super nice,,billet,,etc,,,
[Re: 69CHARGERMD]
#624347
02/27/10 11:19 AM
02/27/10 11:19 AM
Posts: 603 Central Oregon
Rodney
Central Oregon
you may want to mock up the headers in the car so you weld the pipe in the correct place to not interfere with things under there ![](/ubbthreads/images/graemlins/Twocents.gif) I've used both steel braided, black rubber hose and push lock hose
