does it have a single feild wire hook up on the stock alt?
I just did this on my 85 truck that I put a BB in
the 2 feild wires hook up and the batt wire hook up the same and the stock VR runs the output
not sure on a one wire set up though
![](/ubbthreads/images/graemlins/shruggy.gif)
I had to flip the alt over and use the single ear as a pivot point and the double ears as the adjust point with the swing arm
I used the stock non a/c BB truck alt brackets,some long spacer tubes with long bolt to mount it
I used the ps belt that came on the non a/c 440 also
I can send you a pic of the mounting and # for the belt if you want them
![](/ubbthreads/images/graemlins/popcrn.gif)
