Page 12 of 13 1 2 10 11 12 13
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623711
06/22/11 02:48 AM
06/22/11 02:48 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
Headlight wire harness upgraded to switch thru relays and upgraded to heavier gage wire.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623712
06/22/11 02:49 AM
06/22/11 02:49 AM
Relays for fans, fuel pump and headlights on custom made bracket mounted under to battery tray so it is all out of sight.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623713
06/22/11 02:52 AM
06/22/11 02:52 AM
Custom made engine wire harness for alternator, oil pressure, water temp. All other fuctions are thru the separate ECU wiring harness. Also all wiring was modified so no heavy electrical loads go thru the original bulkhead connector.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623714
06/22/11 02:53 AM
06/22/11 02:53 AM
More custom machined aluminum parts. Should get them back from the anodizing shop in a few days.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623715
06/22/11 02:57 AM
06/22/11 02:57 AM
I also got the exhaust system done. 2-1/2" all stainless steel including all clamps, hangers, hardware. All mandrel bent pipes, X-pipe removable with V-clamps in case transmission or clutch need to be changed. This was done by a local shop, it was expensive, but top quality work.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623716
06/22/11 02:58 AM
06/22/11 02:58 AM
Exhaust #2.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623717
06/22/11 03:00 AM
06/22/11 03:00 AM
Also stated working on the interior, stripped and repainted the rear saet frame. Front seats will be aftermarket, done in custom leather, rear seat is being re-upholstered to match.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623718
06/22/11 03:01 AM
06/22/11 03:01 AM
Re-painted.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623719
06/24/11 07:49 AM
06/24/11 07:49 AM
Missouri, Cole county
gbolten480 Offline
gbolten480  Offline
This is such an awesome project! I believe my pupils grow every time I see the pic's & the progress. Thanks for taking the time to show all the little detail that you've gone to! I know I'll definitely be keeping an eye on this.
Re: 70 cuda 340 - finally painted! [Re: gbolten480] #623720
06/25/11 03:12 AM
06/25/11 03:12 AM
I got it fired up today!!! It started right up after about 5 seconds of cranking. Still needs plenty of adjustments to make it driveable, but it runs.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623721
06/25/11 11:38 AM
06/25/11 11:38 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Turning that key for the first after such a great build must be pretty exciting. Your doing a first class job. Keep the updates coming.
Dennis
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: 70 cuda 340 - finally painted! [Re: 19cuda73] #623722
06/26/11 08:07 AM
06/26/11 08:07 AM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
!! Awesome workmanship! I think this is the wave of the future for older mopars as evidence looking at the GM and ford camp. Increased reliability, performance and fuel mileage .I bet you can't wait to drive it!! Please give us some feed back on the comparison to driving old school mopars. Congatulations
Re: 70 cuda 340 - finally painted! [Re: johnscudashop] #623723
07/01/11 02:07 AM
07/01/11 02:07 AM
Sorted out a few minor things in the last few days. Hopefully tomorrow I will take it for a test drive!
Today I assembled and installed the grille and front bumper.
I restored and painted the grille about 1-1/2 years ago. I still had to install all the moldings, turn signals, etc before installation. Like most other things on this car, it took longer than expected.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623724
07/01/11 02:09 AM
07/01/11 02:09 AM
Close-up. The repro red bars needed to be repainted, as the paint on them was very sloppy, and too light.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623725
07/01/11 02:10 AM
07/01/11 02:10 AM
I found a correct NOS PLYMOUTH emblem for it too.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623726
07/01/11 02:11 AM
07/01/11 02:11 AM
Finally installed. I had test fitted it before paint, but is was still a lot of trouble to get it aligned nicely.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623727
07/01/11 02:13 AM
07/01/11 02:13 AM
NOS wiper arms and new metal wiper blades.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623728
07/06/11 03:05 AM
07/06/11 03:05 AM
Here are all the front end parts installed. Now it finally looks complete.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623729
07/06/11 03:14 AM
07/06/11 03:14 AM
After having some problems with the EFI and clutch, today I got it all sorted out, and took it for a test drive!
There are still some adjustments needed with the ECU, but it is totally driveable as is. Also the belt tensioner I made came apart after about 5 miles, the outer aluminum ring came off the bearing due to heat expansion. Made one out of steel with a much tighter press fit, all seems OK now. Also have a problem with the lower rad hose, once everything warms up, it expands a bit and it it too close to the belt. I'll get this sorted out this week. Otherwise the car drove fine, no strange noises, brakes worked well, clutch is a little grabby, but not too bad. The EFI hemi is definitely superior to an old school carbureted engine.
I hope to take it for a longer test drive very soon.
Here is a pic of the completed engine compartment.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623730
07/06/11 03:15 AM
07/06/11 03:15 AM
One more.
