325-50-15's are on #623201
02/24/10 08:43 PM
02/24/10 08:43 PM
NJ
440challenger Offline OP
NJ
Finally got my M/T drag radials. 325-50-15 . found them the cheapest on ebay.
68 roadrunner- 15x10 wheel vintique w/ 5.5 bs.
1/4 spacer on driver side. This has to be the MAX tire size for stock springs/wheel well etc. Not sure if it will rub, but the outer wheel JUST BARELY clears the tire side wall. I have atleast 1/4 to 3/8 clearence to the leaf spring.
Im just worried about the outer wheel lip hitting the outersidewall. i might need to trim/roll the lip. Heres some pics. They really don't do justice. Not sure when i will be able to get the car out for better pics with the snow coming now....
Re: 325-50-15's are on [Re: 440challenger] #623202
02/24/10 08:44 PM
02/24/10 08:44 PM
NJ
NJ
back
Re: 325-50-15's are on [Re: 440challenger] #623203
02/24/10 08:45 PM
02/24/10 08:45 PM
NJ
NJ
lip
Re: 325-50-15's are on [Re: 440challenger] #623204
02/24/10 08:47 PM
02/24/10 08:47 PM
NJ
NJ
tuckin some tire
Re: 325-50-15's are on [Re: 440challenger] #623205
02/24/10 09:55 PM
02/24/10 09:55 PM
Stuart, FL
Grassosgarage Offline
Stuart, FL
I see you have a Challenger. Can these fit on an E-body? What offset??
'70 Cuda 440/auto
'70 Duster 340/4sp project
'70 Satellite convert 318 survivor
Re: 325-50-15's are on [Re: Grassosgarage] #623206
02/24/10 10:12 PM
02/24/10 10:12 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
Nice shoehorn! I'd be a little worried about that lip though. I think you'd be alright with the leaf clearance, I'd still rather have at least 1/2".
Re: 325-50-15's are on [Re: Grassosgarage] #623207
02/24/10 10:20 PM
02/24/10 10:20 PM
NJ
NJ
I dont think they would fit a challenger with out at least off set shackles and a wheel lip trim.
In my sig, i run 27 11.5 15 hooiser qtps on 8 in rims with 4.5 bs. They fit great no rubbing . Thats a big tire for stock everything!
I had 275/60/15s on my rr , and it just looked dinky. I think the rr just needs that big tire to give it a good look. See what happens the next nice day if they rub.
Re: 325-50-15's are on [Re: Grassosgarage] #623208
02/24/10 10:21 PM
02/24/10 10:21 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
cut the lip and move the leafs one inch inboard.
Re: 325-50-15's are on [Re: Nukechargerboy] #623209
02/24/10 11:29 PM
02/24/10 11:29 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
3/8" clearance seems to be common on Dusters like mine with 275/60/15 with 4.5" BS, never had a contact issue so I think you are fine too. You'll need to work the outer lip though it looks like.
Ride eternal, shiny and chrome
Re: 325-50-15's are on [Re: 70blackfish] #623210
02/24/10 11:35 PM
02/24/10 11:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I don't know why you'd put that big of a tire on with so little clearance. Nobody would know the difference if they were a 1/2" or 1" narrower !!
Re: 325-50-15's are on [Re: Stanton] #623211
02/25/10 12:34 AM
02/25/10 12:34 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You'll probably be okay on the leaf spring but will need to trim that wheel lip.
Stanton, who still makes a 295/60/15? I've looked and not found anyone.
Re: 325-50-15's are on [Re: 440challenger] #623212
02/25/10 03:25 AM
02/25/10 03:25 AM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
Those meaty tires look super tough on that car!
Re: 325-50-15's are on [Re: 440challenger] #623213
02/25/10 08:18 AM
02/25/10 08:18 AM
NJ
NJ
I will trim the lip,there is a ton of room to work with there. I put a set of goodmark skins on the car a few years ago so the lip might be larger then stock.
Got my Hemi scoop also. Its a bolt on. I was sick of the cheap fiberglass 6 pack hood i had, so im bolting this to a steel flat hood, then spray the whole deal organisol.
Re: 325-50-15's are on [Re: 440challenger] #623214
02/25/10 09:50 AM
02/25/10 09:50 AM
NJ
NJ
Just cut the lip real quick on the passenger side. Now i have plently of room and enough wheel lip to even put a wheel well moulding on if you wanted to. I think these cars are much different as far as specs, even if its the same car and year.
Re: 325-50-15's are on [Re: DaytonaTurbo] #623215
02/25/10 10:21 AM
02/25/10 10:21 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Those are Hoosier Quick Times. Can't say how old they are - this isn't my car. I saw this car last summer and liked the fit si I snapped a couple shots rather than take notes.
I just looked on Hoosier's website and they don't show any bias-plys.
Re: 325-50-15's are on [Re: DaytonaTurbo] #623216
02/25/10 10:52 AM
02/25/10 10:52 AM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
Hoosier makes it in quick time #17125 also a 29x12.50x15 is almost the same size
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
