Re: Rockers For Big Ez heads
[Re: moparmattkos]
#622684
02/24/10 12:59 PM
02/24/10 12:59 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
These are offset intake rockers. They fit eddy victors. Is the victor offset different than the big ez's?
Victors requires the offset intake rocker like the 440-1s and Big EZs ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: B G Racing]
#622685
02/24/10 01:29 PM
02/24/10 01:29 PM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
Like but not the same Victor uses a .600 offset
[Re: DoubleD]
#622686
02/24/10 02:04 PM
02/24/10 02:04 PM
B G Racing
Eighty Four, PA
Correct me if I'am wrong,,but can't the .800 offset be used with the correct spacers? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: DoubleD]
#622688
02/24/10 02:20 PM
02/24/10 02:20 PM
B G Racing
Eighty Four, PA
I would not want to do that - you would end up offseting the roller tip on the valve stem somewhat - I know some folks tried to slot the push rod hole over. Just not worth the risk of popping a retainer when the right parts are now avaiable for both set-ups. The big issue with those victor heads was the rocker arms at first - the head was released prior to the rockers being available.
![](/ubbthreads/images/graemlins/bow.gif)
