Re: Black radiator cools better than silver [Re: 383'D] #621656
02/24/10 01:30 PM
02/24/10 01:30 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Also consider that if black was so much better at cooling, NASCAR cars would have black radiators where even 5* would be a great benefit. They are not...So it would seem to me that if those guys don't see the benefit there is little or any to be had. Like mentioned before they are black mainly for aesthetics. Somebody call myth-busters. I think we have a show for them.
Re: Black radiator cools better than silver [Re: 383'D] #621657
02/24/10 02:44 PM
02/24/10 02:44 PM
Virginia
BSharp Offline
BSharp  Offline
Virginia
Here's an article from the Department of Energy. Sounds like radiators should be renamed "convectors".
But the real question is, what if the airplane is white and the conveyor belt is black?
Re: Black radiator cools better than silver [Re: Mr.Yuck] #621658
02/24/10 02:50 PM
02/24/10 02:50 PM
NE
moparpoolman Offline
NE
Interesting topic, I wasn't too sure if it works or not BUT Eastwood co. makes a "Radiator Paint specifically formulated to allow the heat transfer". I'm kinda thinking it may just be true.
Re: Black radiator cools better than silver [Re: Mr.Yuck] #621659
02/24/10 03:17 PM
02/24/10 03:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
They run the grill taped up most of the time anyway so obviously cooling isn't an issue. Besides, as previously mentioned, the temp is controlled by the thermostat. It doesn't matter how much heat the rad dissipates, the thermostat will maintain its preset temp.
Everyone seems to be thinking along the lines of "running cooler". Not so. Operating temp is controlled by the thermostat. BUT, if you shut down the engine the car with the black rad would cool down faster.
Re: Black radiator cools better than silver [Re: Stanton] #621660
02/24/10 03:24 PM
02/24/10 03:24 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
"They run the grill taped up most of the time anyway so obviously cooling isn't an issue. Besides, as previously mentioned, the temp is controlled by the thermostat. It doesn't matter how much heat the rad dissipates, the thermostat will maintain its preset temp"
yes but if a BLACK rad cooled better the coolant would be say 230 instead of 235-240. Once the t-stat is open it's open until temps drop under the designed temp. My car has a 160* t-stat in it but the temp will go higher. ....just saying.
Re: Black radiator cools better than silver [Re: Mr.Yuck] #621661
02/24/10 04:22 PM
02/24/10 04:22 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
"Home > Library > Miscellaneous > Britannica Concise Encyclopedia
Thermal Radiation
Process by which energy is emitted by a warm surface. The energy is electromagnetic radiation and so travels at the speed of light and does not require a medium to carry it. Thermal radiation ranges in frequency from infrared rays through visible light to ultraviolet rays. The intensity and frequency distribution of the emitted rays are determined by the nature and temperature of the emitting surface; in general, the hotter the object, the shorter the wavelength. A hotter object is a better emitter than a cooler one, and a blackened surface is a better emitter than a silvered one. An example of thermal radiation is the heating of the Earth by the Sun.
For more information on thermal radiation, visit Britannica.com. "
Re: Black radiator cools better than silver [Re: 6PakBee] #621662
02/24/10 04:45 PM
02/24/10 04:45 PM
Orange Park, FL
MRHWS Offline
MRHWS  Offline
Orange Park, FL
I believe radiators were painted black to hide welded seams and metal discoloration and to match the rest of the underhood compartment.
1973 Charger SE 1974 Charger Rallye 440 Aztec 2008 Charger SRT8
Re: Black radiator cools better than silver [Re: 6PakBee] #621663
02/24/10 05:34 PM
02/24/10 05:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Thermal Radiation
great in theory but does it apply to a cars raditor? will it be enough difference to notice? not likely.
Re: Black radiator cools better than silver [Re: Mr.Yuck] #621664
02/24/10 08:43 PM
02/24/10 08:43 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
It was widely reported back in the day that "Grumpy" Jenkins painted his race engines white to contain heat that would then be converted to mechanical energy. I am of the paint is a better emitter, but think the question of how much insulation paint adds, is a valid one, and the comment on black lacquer is on target.
An example that comes to mind is the enclosed glass bulb with a two side free spinning black sided/white sided flag. When lit by a light/heat source, the black side flag spins away from the energy source, indicating I believe it heats more, and gives up its heat faster, not sure if this is a valid example of anything, but hey this is moparts.
Re: Black radiator cools better than silver [Re: jcc] #621665
02/24/10 08:54 PM
02/24/10 08:54 PM
North Central Florida
E
eightlitermopar Offline
E
Honest question then...not being sarcastic
From what I read here, a black metal roof will actually be better in the summer for cooling my house vs a white metal roof? Is this right? (based on the argument presented for radiating heat?)
eightlitermopar
Mopar or no car
Re: Black radiator cools better than silver [Re: eightlitermopar] #621666
02/24/10 09:01 PM
02/24/10 09:01 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
eightlitermopar
Uh, no. "A hotter object is a better emitter than a cooler one" I would assume that the temperature of your roof is cooler than the temperature of the sun.
Re: Black radiator cools better than silver [Re: eightlitermopar] #621667
02/24/10 09:05 PM
02/24/10 09:05 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Yes and no, But only in the shade, but your example would be based on whether a black shaded roof over an attic space is hotter or cooler then the cooled living space below the attic, which really makes little sense other then for arguments sake, but its also I think why nearly every piece of decent high powered audio equipment has the heat sinks for cooling black in color
Re: Black radiator cools better than silver [Re: jcc] #621668
02/24/10 11:44 PM
02/24/10 11:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Yeah, and a black interior will keep your car cooler on a hot sunny day too !!!
Re: Black radiator cools better than silver [Re: Stanton] #621669
02/24/10 11:53 PM
02/24/10 11:53 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
Come on guyz ...common sense ...
ANY paint on a rad is going to PREVENT(and insulate) the best heat transfer from the rad to the outside air.
The reasons WHY they are painted(oEM) is to prevent or retard outside corrosion.
Re: Black radiator cools better than silver [Re: dOc …] #621670
02/25/10 03:11 AM
02/25/10 03:11 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I know it goes against common sense. BUT- Just how does a positraction rearend work in a 67 Plymouth?? It just does!!
