How to build torque #620965
02/22/10 02:58 PM
02/22/10 02:58 PM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
I'm doing a relatively stock HP 383 build and am either going to go with a stock replacement cam or the XE262H to keep good torque numbers.
What are some other ways of building torque? Increase in timing? Gears? etc.
I'll be driving a 71' Roadrunner, which is at or little over 4000lb. with the options it has and what not. So torque is important to move this tank lol.
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: How to build torque [Re: CurYellowBird] #620966
02/22/10 03:14 PM
02/22/10 03:14 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
A good aluminum intake that makes power from idle or 1500 rpm on up. The Air Gap comes to mind. Poke around a little, I think most cam manufacturers make camshafts specific for towing and low end torque.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: How to build torque [Re: CurYellowBird] #620967
02/22/10 03:49 PM
02/22/10 03:49 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Running a good amount of advance helps. I run 18 degrees initial and 20 mechanical degrees for total of 38 degrees, all in by 2,100 RPM's. I don't run the vacuum advance...yet. That works for me, but you may need to use some trial and error to see what works for you.
FWI: The more initial advance you have the more it will smooth out the idle. At 18 btc my Coronet has a muscle car exhaust sound. At 10 btc it's more noticeable.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: How to build torque [Re: Junky] #620968
02/22/10 04:34 PM
02/22/10 04:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Like said, good timing curve. Also, a high compression ratio always helps. And a higher stall converter will really help too because it allows your motor to jump up to it's torq peak when you nail the throttle.
Re: How to build torque [Re: DaytonaTurbo] #620969
02/22/10 04:56 PM
02/22/10 04:56 PM
scratchnfotraction Offline
the whiplash from hughes has early intake closeing to build cyl pressure so it wont kill off any torque
in a low CR engine
thats gonna be my way of making some torque
Re: How to build torque [Re: scratchnfotraction] #620970
02/22/10 06:33 PM
02/22/10 06:33 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
well, if it's torque you want, then you'll be looking to maximize power at lower RPM, vs spinning it to 7500rpm for max power.
you'll want long intake and exhaust runners, smaller (stock sized) valves to keep air velocity up at the lower RPMs, and a smaller carb for the same reason.
the long runners like on a cross ram intake with the carbs out over the fenders, will make peak power at a much lower RPM due to the time it takes for the pressure waves to bounce back and forth inside. short runner intakes will make peak power at higher RPMs. same goes for exhaust, longer primaries on the headers makes for lower RPM peak power.
but, a cross ram or tunnel ram may be a bit extreme. an intake like the perf. RPM is a good compromise and will make good low end torque. any long tube header with a smaller primary size will also suffice.
**Photobucket sucks**
Re: How to build torque [Re: CurYellowBird] #620971
02/22/10 06:45 PM
02/22/10 06:45 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Well the stock engine did a pretty good job of moving that "tank" so if you build it along those lines you should do ok.
Stick to 9.5:1 compression with iron heads so you can run on pump gas.
Dual plane intakes provide more torque than single planes's.
Spread-bore carb with vaccuum secondaries. If it comes down to a decision between 2 sizes, go with the smaller.
Small tube headers - 1-5/8 - 1-3/4 MAX
X or H pipe in the exhaust system
The most important thing will be the cam choice.
Do it right and the converter will the least of your worries ... it'll pull stumps out at idle!
Re: How to build torque [Re: Stanton] #620972
02/22/10 07:09 PM
02/22/10 07:09 PM
San Antonio, TX
San Antonio, TX
I'll be keeping the HP manifolds and probably the HP intake. I've heard good things about the HP intake flowing just as good as a performer, its just heavy as hell.
For compression, I think the 71' engines were 8.5:1 so I'm gonna definately get that up to par. I have a carter AFB 750cfm carb that the previous owner put on. I don't have the original one. I messed with camquest and the original cam specs or the XE262H is giving the best torque numbers along with good HP numbers.
What about exhaust tube sizing? I know 3 inch is far to large for a torque oriented build. I have the original exhaust that is quite clean and can be reused. I think it is 2 1/4 size tubing, but of course does not have a h-pipe.
Re: How to build torque [Re: CurYellowBird] #620973
02/22/10 07:49 PM
02/22/10 07:49 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
stroker kit
Re: How to build torque [Re: SomeCarGuy] #620974
02/22/10 07:54 PM
02/22/10 07:54 PM
stroker kit
this.
otherwise your gonna need alotta rpm to get some
nice torque #'s.
Re: How to build torque #620975
02/22/10 08:00 PM
02/22/10 08:00 PM
San Antonio, TX
San Antonio, TX
A lot of rpm to make torque? Isn't it the other way around where a lot of rpm makes horsepower?
I'm not stroking the numbers engine. I'm just looking at doing basic improvements to improve the engines performance and make up for some lost hp/lb. numbers in 71'.
Re: How to build torque [Re: CurYellowBird] #620976
02/22/10 08:19 PM
02/22/10 08:19 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Just stick with your plan. XE262H cam.
Work on the timing and carb setup. Tune, tune, tune!
Run that 2 1/4 inch exhaust with some good flowing mufflers. Add an H or X pipe if you can.
The Edelbrock Performer RPM intake will really help over a stock intake, but it's almost 2" taller than the stock intake.
If you need to do any head work, have them blended, milled 0.030 or 0.040 and have a 3 angle valve job, and use the steal shim head gaskets.
All this will give you a good running cruiser that'll run stronger than a stock 1970 Road Runner 383.
Your running a 4 speed, right?
Re: How to build torque [Re: CurYellowBird] #620977
02/22/10 08:22 PM
02/22/10 08:22 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
Build it bigger I say,you have it if you need it and if you don't use it you still have it.I'm talking cubes. Just my
Re: How to build torque [Re: Junky] #620978
02/22/10 08:48 PM
02/22/10 08:48 PM
San Antonio, TX
San Antonio, TX
Yep Junky, I am running a 4 speed
Re: How to build torque [Re: CurYellowBird] #620979
02/22/10 08:51 PM
02/22/10 08:51 PM
Kirkland, Washington
Pacnorthcuda Offline
Since you mentioned gears in your original post, you're obviously not talking just engine mods.
Higher (numerically) gears will reap HUGE benefits at the rear tires.
Re: How to build torque [Re: CurYellowBird] #620980
02/22/10 08:56 PM
02/22/10 08:56 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
For compression, I think the 71' engines were 8.5:1 so I'm gonna definately get that up to par. I have a carter AFB 750cfm carb that the previous owner put on. I don't have the original one. I messed with camquest and the original cam specs or the XE262H is giving the best torque numbers along with good HP numbers. quote]
Sports post.
Definately get that comp up, using the shim gasket will help. The stock HP exhausts are fine but you will give to much HP up with the stock intake. The RPM will net you more overall torque and HP for a better balance of what your doing.
Depending on your final compression and cranking CLY pressure you can also advance the cam for more low to midrange torque with very little to no loss of HP below 6000 rpm. mike
Re: How to build torque [Re: Sport440] #620981
02/23/10 12:59 AM
02/23/10 12:59 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I like the mild cam, and timing curve idea, but I'm going to respectfully disagree on the rpm intake.
Go with the regular performer instead.
I'm pretty sure the specs on the rpm specify that it is meant for lighter stuff, and higher stalls. I have a 400 I built for moving my 5000 plus van around, and it seems to work best with a stock iron intake.
Don't get me wrong here, I run an rpm in my 330, but it's a little wilder. I think a regular performer, and tune it with 4 hole spacers to get a little more torque out of it, would be best for this 383.
Re: How to build torque [Re: dave571] #620982
02/23/10 02:55 AM
02/23/10 02:55 AM
Manitoba, Canada
Manitoba, Canada
Mild cam and bone stock heads, stick with the stock intake or a performer or dp4b. A bit smaller runners keep the port velocity up which is what you want for torq. The RPM intake will actually give up a little torq down low compared to the other intakes I mentioned because of it's larger runner volume, which is unnecessary for his application.
Re: How to build torque [Re: DaytonaTurbo] #620983
02/23/10 08:53 AM
02/23/10 08:53 AM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
Where does torque come from?
I will tell you. It comes from the energy released from the fuel you burn. The more fuel you burn the more torque you have.
Simple as.
So larger capacity, forced induction, NOS, etc will all give you big torque.
Where you make that torque (at what rpm) is what decides how much HP you have.
All torque at low rpm makes for a poor performance engine. Like a steam engine or truck.
You are better making torque at high rpms if you want a good top speed.
That is where the cam (valve timing) comes in.
Best way to improve torque on a 383 is to stroke it or throw it out and fit a 440.
2002 Chevrolet Corvette 5.7 LS1 2011 Alpha Romeo Giulietta Veloce 1.6 JTD Because running a Mopar in the UK is getting TOO expensive!!
Re: How to build torque [Re: Roppa440] #620984
02/23/10 10:40 AM
02/23/10 10:40 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
headers are the cheapest way to make torque...in just about every BB dyno shootout Dulcich has done in Mopar Muscle, long tube headers usually pick up ~20 lb-ft over stock exhaust manifolds.
for your 383, I'd also run KB flat tops at 0 deck with closed chambered heads.
2017 Grand Cherokee Overland
