Re: NE1 make a set of really cool small block valve covers? [Re: RUMBLON] #61978
06/06/08 08:31 PM
06/06/08 08:31 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
I would say if you want to paint them, get the polished model, the black wrinkle paint would probably be a hassle to strip. It would be more expensive, but cheaper than the MP ones (which I doubt are of higher quality).
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: NE1 make a set of really cool small block valve covers? [Re: kick_the_reverb] #61979
06/06/08 08:58 PM
06/06/08 08:58 PM
moparx Offline
moparx  Offline
if you look closely, it appears the weiand script "box" is the same as the cp blank "box". the ribs look identical. i wonder if these are somehow cast by the same foundry and there are different "core box blanks" used for different manufactures ?
Re: NE1 make a set of really cool small block valve covers? [Re: moparx] #61980
06/06/08 09:07 PM
06/06/08 09:07 PM
Escondido, CA
Escondido, CA
Here's what I wrote in this thread about those Weiand covers:
https://board.moparts.org/ubbthreads/show...e=0#Post4472331
"These look to be the same ones but without the top of the fins machined, with the Weiand logo put in the empty rectangle and of course with some creative painting. I suspect you can do the same with the polished model of the CP Proucts valve covers (a little more expensive than the black wrinkle that I have).
If I'm not mistaken, PAW also sells these, but they are more expensive there."
So, yes, I think they are the same.
Ran
Re: NE1 make a set of really cool small block valve covers? [Re: kick_the_reverb] #61981
06/06/08 10:14 PM
06/06/08 10:14 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Ran
VERRRRRRRRY INTERESSSSTING!!!!!!!!!!!!!!!
Re: NE1 make a set of really cool small block valve covers? [Re: RUMBLON] #61982
08/14/08 08:42 AM
08/14/08 08:42 AM
Virginia
BSharp Offline
BSharp  Offline
Virginia
I just finished these and posted pics on the weekend, so you may have missed them.
I almost went with these because that blank box is like it was made for those fish emblems, but I decided I wanted something a little smoother looking.
OK, I know this is thread is drifting all over the place, but to add to the above info, there are also:
CP products cast aluminum ribbed covers in Black wrinkle or polished. They look sorta like the M/T but they have a blank rectangle in the middle (for putting a name plate, I guess). They're less boxy, maybe they're more like the MP covers.
Re: NE1 make a set of really cool small block valve covers? [Re: BSharp] #61983
08/14/08 10:13 PM
08/14/08 10:13 PM
central Kentucky
moprod Offline
moprod  Offline
central Kentucky
Speaking of finned covers, how do you powdercoat finned covers and keep fins shiney?
[img] [/img]
Re: NE1 make a set of really cool small block valve covers? [Re: moprod] #61984
08/14/08 10:51 PM
08/14/08 10:51 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I'd guess you would powdercoat the color, polish the ribs, then powdercoat the clear...
Re: NE1 make a set of really cool small block valve covers? [Re: BSharp] #61985
08/15/08 12:38 AM
08/15/08 12:38 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Thats a nice touch, did you stick painted emblems on them? and if yes, how so?
Re: NE1 make a set of really cool small block valve covers? [Re: RUMBLON] #61986
08/15/08 07:25 AM
08/15/08 07:25 AM
Virginia
BSharp Offline
BSharp  Offline
Virginia
I had some old fender emblems that for some reason had the original studs cut off the back. I ran some small machine screws up from inside the cover, leaving a bit of thread on top. I sealed the heads with JB, and JB'd the fish to the stubs. There's enough of a cavity to hold the epoxy.
Re: NE1 make a set of really cool small block valve covers? [Re: BSharp] #61987
03/21/12 06:47 AM
03/21/12 06:47 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
http://www.ebay.com/itm/ws/eBayISAPI.dll...c#ht_1038wt_825 I have a set of these on my car. I also have a spare set. I like that there's just fins and no logo or square etc.
Re: NE1 make a set of really cool small block valve covers? [Re: poorboy] #61988
03/21/12 06:46 PM
03/21/12 06:46 PM
Pa. bucks county
cuhemida Offline
cuhemida  Offline
Pa. bucks county
no biggy get a cope and a drag some casting sand and a good hot fire and cast your own
