Page 2 of 3 1 2 3
Re: boosted cams,post yours. [Re: BigBlockMopar] #618487
02/27/10 12:16 AM
02/27/10 12:16 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Bullet solid flat tappet
259/255 @ .050
.625/.620 @ 1.6
114 deg centerline
hopefully getting motor together tomorrow!
408ci
Indy 360-2 230cc
Twin 67mm turbos
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: boosted cams,post yours. [Re: blownzoom440] #618488
03/01/10 01:19 PM
03/01/10 01:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
For my blown 451" BAE motor.
Re: boosted cams,post yours. [Re: blownzoom440] #618489
03/01/10 04:56 PM
03/01/10 04:56 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Intake Duration at .050 inch Lift 242
Exhaust Duration at .050 inch Lift 248
Intake Duration 280
Exhaust Duration 286
Intake Valve Lift 0.570 in.
Exhaust Valve Lift 0.576 in.
Lobe Separation (degrees) 110
Intake Valve Lash 0.016 in.
Exhaust Valve Lash 0.018 in.
my solid roller, one of the remaining parts from my old N/A 340 and i will keep it in my newbuilt
340 with the old ported edelbrock heads
but new milled down TRW pistons making 8.1:1compresion
and a lysholm twinscrew, hope it will make som power at 15psi on pumpfuel i know im new to building a blown engine and this may be far from perfect but i hope it will work fairly good
Re: boosted cams,post yours. [Re: 1Fast340] #618490
03/02/10 12:35 AM
03/02/10 12:35 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
After trying ALOT of cams and turbos on the same basic engine, I came up with some very basic self tested rules:
The smaller the turbine, the smaller and wider you want the cam.
Pump gas likes less lsa at higher boost levels.
Race gas likes more lsa (seems backward doesn't it?)
A free flowing turbine/wheel combo will like a cam closer to that of a n/a engine, don't be afraid of a 260+ cam.
Re: boosted cams,post yours. [Re: TRENDZ] #618491
03/02/10 09:40 PM
03/02/10 09:40 PM
huron,ohio
b1headman Offline
b1headman  Offline
huron,ohio
290@.050 int 298@.050 ex .800 int lift .780 ex lift 114 lsa
Re: boosted cams,post yours. [Re: b1headman] #618492
03/05/10 12:52 AM
03/05/10 12:52 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Scott you need to put some cam in that thing
Re: boosted cams,post yours. [Re: roadhazard] #618493
03/14/10 11:31 AM
03/14/10 11:31 AM
ky
headhunter Offline
headhunter  Offline
ky
ok dumb question time as you can tell im full of them lol. how bad is it to run a n/a cam in a turbo motor?like a comp cams 305-305 525-525 hyd with a 110 centerline? does running the n/a cam hurt the motor
Re: boosted cams,post yours. [Re: headhunter] #618494
03/14/10 07:44 PM
03/14/10 07:44 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
A cam like that would really flatten out engine performance, unless you had HUGE turbine wheel(s) and housing(s). There is to much int/ex overlap to run a normal turbine selection. On the positive side, you wouldn't hurt your engine with a cam like that. You would contaminate the intake charge with alot of exhaust gas. You wouldn't make enough power to hurt anything.
Re: boosted cams,post yours. [Re: TRENDZ] #618495
03/20/10 08:11 AM
03/20/10 08:11 AM
ky
headhunter Offline
headhunter  Offline
ky
orderes my cam today from bullet cams its a 246-250 at 50 and 525-540 lift with a 114 lsa think it will be a decent cam for a 446 with a 88mm ball bearing unit?
Re: boosted cams,post yours. [Re: headhunter] #618496
03/20/10 12:00 PM
03/20/10 12:00 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Sounds like a real nice choice to me.
Re: boosted cams,post yours. [Re: feets] #618497
03/22/10 02:07 AM
03/22/10 02:07 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Here's my monster cam specs. Think you can hang with this baby? This is rocket science right here!
intake/exhaust
.006 duration 284/280
lift .474/.483
.050 intake open 6 btdc close 50 abdc
.050 exhaust open 48 bbdc close 4 atdc
duration at .050 236/232
lobe lift .3160/.3220
separation 112
You can see there's only 10 degrees of overlap. That's as tight as we could get it without going to a custom blank.
Keep in mind that this cam was ground 10 years ago. Comp wasn't doing a lot of turbo cams since turbos V8s weren't very common.
Much has changed since this thing was built. I'm sure people know far more about turbo cams now than they did then. However, this thing makes decent power. You can't argue with that.
Your overlap is 58 degrees. It makes no sense to give overlap at .050 although I see lots of confusion from even folks that should know better. I don't mean that cam is wrong for your application and overlap done right is a good thing.
Re: boosted cams,post yours. [Re: goldmember] #618498
03/22/10 02:08 PM
03/22/10 02:08 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You're the first one who's ever brought that up. All I know is that was as close as Comp could grind it without going to a custom blank. I wanted as little as possible.
It's worked for several years so I guess I can't complain too much.
- Stu Harmon
Re: boosted cams,post yours. [Re: feets] #618499
03/22/10 04:07 PM
03/22/10 04:07 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
and that is what comp told me about my roller i listed.i have 40* overlap at .050 and 70* total.
Re: boosted cams,post yours. [Re: blownzoom440] #618500
03/22/10 06:19 PM
03/22/10 06:19 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Yours is a roller which does change things but it's still a lot more cam than what I've got.
- Stu Harmon
Re: boosted cams,post yours. [Re: feets] #618501
03/22/10 06:51 PM
03/22/10 06:51 PM
ELYRIA,OH
ELYRIA,OH
i dont know how much i gained with the cam change going to a roller because my carbs were holding me back. that also effected my cam choice where i may have gone another way.
Re: boosted cams,post yours. [Re: blownzoom440] #618502
03/22/10 09:32 PM
03/22/10 09:32 PM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
I sent all my info to Comp to have them spec a cam for my indy head turbo big block, and this is what they sent me back.
Part #: 23-000-9
Grind #: 4001/4121 R115+2
Duration @ .050”: 248/244
Lift w/ 1.5 Ratio: .630/.615
LSA: 115
Advance: +2
www.sikosracing.net Heads up Drag racing
Re: boosted cams,post yours. [Re: moparmattkos] #618503
03/23/10 03:23 AM
03/23/10 03:23 AM
ELYRIA,OH
ELYRIA,OH
any track results with that yet.i have more duration because i am running a factory 346 iron head.
Re: boosted cams,post yours. [Re: blownzoom440] #618504
03/24/10 08:49 AM
03/24/10 08:49 AM
MN
hemidup Offline
hemidup  Offline
MN
I'm thinking about a cam swap. Currently running a Paxton blower with a 216/220, 114 LSA. I have 2 other cams I could use. One a 219/224, 114 LSA and the other a 205/210, 116 LSA. Also have 4.56 gears and 3800 stall. The truck has always e.t'd better than MPH.
Jerry Williams.
Re: boosted cams,post yours. [Re: hemidup] #618505
03/24/10 09:01 AM
03/24/10 09:01 AM
ELYRIA,OH
ELYRIA,OH
something like a 4.10 gear might help.i think we need more info on your combo,performance.
Re: boosted cams,post yours. [Re: blownzoom440] #618506
03/24/10 09:40 AM
03/24/10 09:40 AM
MN
hemidup Offline
hemidup  Offline
MN
The truck has 3.92's, but with the small selection of 17" drag radials available, the gear ratio works out close to 4.56. 3.0 1st gear, 1.67 2nd and 1:1 3rd. She weighs in at a whopping 5166 lbs. 1.48 60' and I'm in 3rd by the 330 going through the 1/4 mi traps in the top of 3rd at 6200 rpm. I'm happy as heck with her 1-2, 2-3 performance. Run high 6.80's @ 98 in the 1/8th but she just doesn't pull as hard as she should in 3rd running 11 flat with mid teens in the 1/4. I use w/m and at times have given the engine a small 30 shot of n2o to make sure the ait's stayed in check. I was just wondering if changing out to a cam with a wider power band would help in 3rd?
Jerry Williams.
Page 2 of 3 1 2 3
