Re: Too much compression for pump gas? [Re: 602heavy] #617565
02/20/10 09:45 PM
02/20/10 09:45 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
my static will come in at 11.4, dynamic will be 9.85 with 207psi cranking. looks like pump gas may be out for me even though i will have .040" quench. will see.
Re: Too much compression for pump gas? [Re: mopar dave] #617566
02/21/10 09:46 AM
02/21/10 09:46 AM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
Also double check valve clearence if you haven't already done so. The pro com heads I have are 2.25 intake and 1.88 exhaust. They hit the 426ci 4.25 bore block and my shalow valve pockets on my stock street wedge piston about the same time. I was trying to lift .570
Re: Too much compression for pump gas? [Re: Maximus_Wedges] #617567
02/21/10 02:02 PM
02/21/10 02:02 PM
Fort Worth, TX
Dago Red Offline
Dago Red  Offline
Fort Worth, TX
My biggest problem with pump gas has never been detonation, but inconsistancy. My buggy only has around 8.5 but every so often it tosses out a really off pace run or picks up. I went to the 100 unleaded gas and it stopped. All fillin' station fuel is not created equal.
If You Can't Be Good, At Least Be Colorful
Re: Too much compression for pump gas? [Re: Dago Red] #617568
02/22/10 08:57 AM
02/22/10 08:57 AM
Spokane,WA
Genuinejed Offline OP
Spokane,WA
Thanks for the input. The motor is stock 440 bore and I checked valve clearance on a 440 and it looks fine. The pistons have some pretty decent reliefs, and I plan on checking clearance there. The heads are off right now waitting on parts. I think quench is gonna be a strech at .025 in the hole, and a .039 head gasket. I was thinking about putting on a thick head gasket to drop the compression a tad since now would be the time. dynamic calculator says my CR should be 10.7 to one.
1968 Plymouth road runner 1968 Dodge Coronet 500 64 D200 Good, Fast, Cheap. Pick Two.
