Semi polished intake ports on 340 Head: OK or not? #616474
02/17/10 11:01 PM
02/17/10 11:01 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
I have a set of 1971 2.02 U Heads, that someone spent countless hours on porting them. The intake ports are so smooth that I am concerned about them being too smooth. I would describe the finish to be semi polished. It looks like they were ported with approx 320 grit rolls. They left no stone unturned and the entire port is done this way, with no signs of any of the original rough casting left. Are these heads OK to use for any type of application? If not, is there anyway to save them? Thanks.
Re: Semi polished intake ports on 340 Head: OK or not? [Re: ragtop] #616475
02/17/10 11:44 PM
02/17/10 11:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Some say they should have some roughness to help
mix the A/F.... so if you hit them with a 120 grit
tootsie rolls it should be fine... basically just
rough them up some dont change the ports (unless
they need it)
Re: Semi polished intake ports on 340 Head: OK or not? [Re: ragtop] #616476
02/18/10 12:11 AM
02/18/10 12:11 AM
detroit area
moderncylinder Offline
detroit area
sand blast them
Re: Semi polished intake ports on 340 Head: OK or not? [Re: MR_P_BODY] #616477
02/18/10 12:15 AM
02/18/10 12:15 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
60 grit at the most. I don't use a sand roll in my stuff at all.
Re: Semi polished intake ports on 340 Head: OK or not? [Re: S/ST 3040] #616478
02/18/10 12:23 AM
02/18/10 12:23 AM
S/ST 3040 Offline
S/ST 3040  Offline
.....unless I have to.
Re: Semi polished intake ports on 340 Head: OK or not? [Re: S/ST 3040] #616479
02/18/10 01:13 PM
02/18/10 01:13 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Man how do you know what is an acceptable amount of the intake valve guide that can be removed? I am home/hobbyist working some J heads. I am too scared to remove real bulk from that guide so I just used a 60grit roll and removed casting bumps, slag and blemishes.
Keep old mopars alive.
Re: Semi polished intake ports on 340 Head: OK or not? [Re: moderncylinder] #616480
02/18/10 01:16 PM
02/18/10 01:16 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
sand blast them
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Semi polished intake ports on 340 Head: OK or not? [Re: ragtop] #616481
02/18/10 03:40 PM
02/18/10 03:40 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Hit 'em with 60 grit rolls.
If you don't have any you'll find they're the ones you'd use the most if you did have them and they come in handy.
Re: Semi polished intake ports on 340 Head: OK or not? [Re: dodgeboy11] #616482
02/18/10 06:26 PM
02/18/10 06:26 PM
dulcich Offline
dulcich  Offline
You are getting overly concerned about nothing. You are going to be wasting your time and effort "roughing" the ports for no benefit whatsoever. Case of some "theory" getting blown way out of proportion. I can say sandblasting or running a sandpaper roll over the existing ports will be unlikely to give any noticable improvement. Put those heads together and consider yourself lucky you found a set of ported heads.
-dulcich
Re: Semi polished intake ports on 340 Head: OK or not? [Re: dulcich] #616483
02/18/10 06:55 PM
02/18/10 06:55 PM
S/ST 3040 Offline
S/ST 3040  Offline
I would add........If they were finished with 320 grit, there's a good
chance they didn't know what they were doing to begin with.
The head I have pictured, was finished with 60 grit so, it may just appear
to be too fine of finish. Here is a 60 grit finish in a different light.
(The port, not the chamber)
Re: Semi polished intake ports on 340 Head: OK or not? [Re: S/ST 3040] #616484
02/18/10 10:50 PM
02/18/10 10:50 PM
The Great White North
RAMM Offline
RAMM  Offline
I hardly ever use a sand (tootsie) roll. I just touch up the carbide marks with a grinding stone--maybe. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
