Motor mounts same for A to E body #615732
02/17/10 02:20 PM
02/17/10 02:20 PM
magna Offline OP
magna  Offline OP
Does anyone know if 1972 340 motor mounts for an A body and an E body are the same?
Re: Motor mounts same for A to E body [Re: magna] #615733
02/17/10 08:51 PM
02/17/10 08:51 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The motor plates are, not the rubber mounts though, 2 COMPLETELY different animals
Mike
Re: Motor mounts same for A to E body [Re: magna] #615734
02/17/10 09:35 PM
02/17/10 09:35 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
These are A- body
Re: Motor mounts same for A to E body [Re: krw71ragtop] #615735
02/17/10 10:36 PM
02/17/10 10:36 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
These are A- body
Those are spool mounts. 73 and up
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Motor mounts same for A to E body [Re: krw71ragtop] #615736
02/17/10 10:36 PM
02/17/10 10:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
These are A- body
Those look like 73 spool design?...correct?
Re: Motor mounts same for A to E body [Re: 69L78Nova] #615737
02/17/10 10:48 PM
02/17/10 10:48 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
These are A- body
That's what I thought when I saw them,...73-88 spool aplication
heres the 68-72 A body mounts, remove the rubber isolator/mount from the engine brackets, 1 bolt and........
Re: Motor mounts same for A to E body [Re: DAYCLONA] #615738
02/17/10 10:50 PM
02/17/10 10:50 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Bolt these on the the engine plates and you are good to go,....B C E body rubber isolators
Re: Motor mounts same for A to E body [Re: magna] #615739
02/17/10 11:58 PM
02/17/10 11:58 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Are you asking about the biscuits or the brackets that mount on the engines
They are different.
The spot where the biscuit attaches to is more forward on A body brackets and towards the rear on E body brackets.
Re: Motor mounts same for A to E body [Re: RobX4406] #615740
02/18/10 10:13 AM
02/18/10 10:13 AM
magna Offline OP
magna  Offline OP
was thinking about putting a 340 with motor mounts and brackets of A-body in a 340 e-body car. The problem is I have no motor mounts or brackets for the 340 E-body car. Only the k member. It appears I will need to order new mounts for the e-body.
