Page 1 of 15 1 2 3 14 15
"Don't ask me how I know..." #613
07/11/03 02:40 PM
07/11/03 02:40 PM
Virginia
BSharp Offline OP
BSharp  Offline OP
Virginia
...is my favorite Moparts quote. It usually comes right after something like, "you can use a battery to weld a half-inch box wrench to your inner fender".
Re: "Don't ask me how I know..." [Re: BSharp] #614
07/11/03 02:43 PM
07/11/03 02:43 PM
Richmond, VA
VT_Dart Offline
VT_Dart  Offline
Richmond, VA
Cars can roll over a 4x4 chunk of wood if placed on a hill without an e-brake... which can lead to the car almost rolling down the hillside and into a creek. However, diving through the open window, hitting the brakes, and snapping off a mirror in the process can stop the car. Don't ask me how I know...
Darrah
Darrah Heath
Re: "Don't ask me how I know..." [Re: BSharp] #615
07/11/03 02:43 PM
07/11/03 02:43 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
ouch, lol i did that, got a good burn from it to i never seen a wrench glow such a pretty shade of red
Re: "Don't ask me how I know..." [Re: BSharp] #616
07/11/03 02:47 PM
07/11/03 02:47 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Batteries can explode during jump starting- and throw sulphuric acid all over you and your car...
Re: "Don't ask me how I know..." [Re: Tom_440] #617
07/11/03 02:53 PM
07/11/03 02:53 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
you can fry your car stereo if you are in a huge hurry and accidently put your jumper cables on backwards...don't ask me how i know!
Re: "Don't ask me how I know..." [Re: nutso suave] #618
07/11/03 03:01 PM
07/11/03 03:01 PM
the left coast
Hank Offline
Hank  Offline
the left coast
When changing the oil, you can get motor oil all over your driveway and piss off your girlfriend if you don't check to make sure the cap is screwed on tight on the nifty oil drain pan you bought at the auto supply store. Don't ask me how I know this...
Re: "Don't ask me how I know..." [Re: Hank] #619
07/11/03 03:04 PM
07/11/03 03:04 PM
When looking to mount a buss fuse block, you can drill a hole into the heater core and squirt antifreeze in your eye... "Dont ask me how I know"
Re: "Don't ask me how I know..." #620
07/11/03 03:07 PM
07/11/03 03:07 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
best yet.
Re: "Don't ask me how I know..." [Re: BSharp] #621
07/11/03 03:09 PM
07/11/03 03:09 PM
Brake parts cleaner when sprayed directly into a wheel cylinder will make a 180 degree turn, get in your eye and temporarily blind you...
Re: "Don't ask me how I know..." #622
07/11/03 03:13 PM
07/11/03 03:13 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
transmission fluid makes your hair nice and shiney
Re: "Don't ask me how I know..." [Re: BSharp] #623
07/11/03 03:15 PM
07/11/03 03:15 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Siphoning (drinking) gasoline through a garden hose makes you burp fumes for 2 days.
Re: "Don't ask me how I know..." [Re: Dakota_Don] #624
07/11/03 03:16 PM
07/11/03 03:16 PM
It's really easy to break off the dipstick tube in a smallblock when trying to re-install the A/C compressor on the front of the engine.
It's really hard to get the small part that's in the block OUT!
Re: "Don't ask me how I know..." #625
07/11/03 03:28 PM
07/11/03 03:28 PM
Santa Rosa, NOR*CAL.
Just Cameron Offline
When removing a PH8A (Instead of a PH43) oil filter off a small block A body, trying to get it to clear the torsion bar leads to dumping hot oil all over your chest.
Re: "Don't ask me how I know..." [Re: Just Cameron] #626
07/11/03 03:29 PM
07/11/03 03:29 PM
Dropping a fullsize starter on your own head hurts...
Re: "Don't ask me how I know..." #627
07/11/03 03:29 PM
07/11/03 03:29 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
when drilling holes for seats you can easily drill threw your fuel line.
Re: "Don't ask me how I know..." [Re: Just Cameron] #628
07/11/03 03:31 PM
07/11/03 03:31 PM
Turning a reverse thread lug to the left will NOT help you get your driver side wheels off, no matter how much you jump on the tire iron and cuss.
Post deleted by moparts [Re: Just Cameron] #629
07/11/03 03:33 PM
07/11/03 03:33 PM
Re: "Don't ask me how I know..." [Re: Just Cameron] #630
07/11/03 03:34 PM
07/11/03 03:34 PM
Don't open the doors on a $100 unibody parts car you've just finished Sawzalling into a cheap summer convertible. Ever. Especially both at once. Especially if its rusty. Just jump in.
Re: "Don't ask me how I know..." #631
07/11/03 03:37 PM
07/11/03 03:37 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Given a hot enough spark, brake fluid will ignite..........................
Starter cables are routed a certain way for a reason.................................
John
Re: "Don't ask me how I know..." [Re: Just Cameron] #632
07/11/03 03:37 PM
07/11/03 03:37 PM
Licking a bananna slug numbs your tongue.
You can feed chickens Twinkies and Mountain Dew.
