Re: Pushrod problems
[Re: Dartin]
#614943
02/16/10 08:45 PM
02/16/10 08:45 PM
Posts: 1,001 Clinton Township, Michigan
Dartin
Sorry the pics are so big and unclear. The formed end of the pushrod collapsed and took out a rocker arem Not pretty. But wait! There's more. I took the pushrods back to the manufacturer and they admitted that they were not heat treated properly. A new set was made with a ball insert and heat treated properly. I paid for the upgrade on the insert. [image] [/image]
[Re: Dartin]
#614946
02/16/10 09:14 PM
02/16/10 09:14 PM
Posts: 4,211 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
WOW! With the end coming off like that, it will be easy to shorten the pushrod anyway. That rocker should buff right out too...$$$ 230 lbs. seat/530 lbs. nose is all those pushrods ever saw.
[Re: Dartin]
#614948
02/16/10 11:14 PM
02/16/10 11:14 PM
Posts: 587 San Clemente, ca
enelson
mopar addict
mopar addict
San Clemente, ca
I'm at my wits end with this company. While I was there they told about all the companies they make pushrods for. I don't want to throw them under the bus until I talk to them in the morning and see how they handle it but i will say that there have been known problems with some of their customers pushrods....
call smith bros or manton and be done.... I wouldnt run any other aside from stock or warmly modded stuff...
[Re: stevehiss]
#614951
02/17/10 06:26 AM
02/17/10 06:26 AM
Dartin
i usually just squeeze the end so the cup fits tight
is the 7 runs on the the motor since it was built or just on the pushrods
why did you get them from a company if you knew others have had issues with them,just curious
the rocker is junk in my opinion
The 7 runs are on the pushrods.
I was unaware of the problems with them when I had them make the first set. Only reason I had a second set made was that they wanted to make things right.
Rocker is obviously junk.
