Pros and Cons of painted on stripes? #614493
02/16/10 11:34 AM
02/16/10 11:34 AM
Missouri
MY340 Offline OP
MY340  Offline OP
Missouri
I've been thinking when I have my FE5 Duster repainted I'll have the stripes painted on semi- gloss black possibly. I'll go with a base/clearcoat paint job.
I'd appreciate some opinions on having the stripes painted on instead of stripe decals.
Does it add much to the cost of the paint job?
TIA
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Pros and Cons of painted on stripes? [Re: MY340] #614494
02/16/10 12:26 PM
02/16/10 12:26 PM
San Antonio, TX
CurYellowBird Offline
San Antonio, TX
Depends on whether your doing the paint job yourself or not.
I painted a set of chevy racing stripes on my 80' malibu and they look great if not better than decals. Paint is going to last longer than decals IMO. I won't be painting the decals on my roadrunner cause that takes a lot of measurements to get the exact factory look, along with the pinstripes on the hood and what not.
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: Pros and Cons of painted on stripes? [Re: CurYellowBird] #614495
02/16/10 12:37 PM
02/16/10 12:37 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
I only saw one car (a challenger) that had painted on stripes that looked half way good. They always seem to look wrong in some way. the decals on dads t/a challenger have been on there since 82 and they still look brand new. Id spend the money getting decals IMO.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Pros and Cons of painted on stripes? [Re: mopars_1] #614496
02/16/10 01:24 PM
02/16/10 01:24 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
The painted stripes will be shiny. Most decals will be satin or flat...
Re: Pros and Cons of painted on stripes? [Re: HemiDave] #614497
02/16/10 02:49 PM
02/16/10 02:49 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I did mine on a 1970 Dart. The decals are a matte. I bought the set of bumblebee stripes from Year One (which was apparently made on 3M backed paper) and I applied them with a help of a friend...they went on very easy. 2 years later the top stripe was faded away and the sides were still semi gloss. A year after that stage the top decal on the trunk started peeling apart.
I eventually had mine painted on at the next paint job, under the clear coat and it looked Fan tastic.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Pros and Cons of painted on stripes? [Re: Pyper70] #614498
02/16/10 09:12 PM
02/16/10 09:12 PM
Central Utah
Mopargnome Offline
Mopargnome  Offline
Central Utah
Painted on stripes last alot longer if good material is used. It will probably cost about the same as buying a sticker. I'm a paint and body guy so anything I do will have painted stripes.
Re: Pros and Cons of painted on stripes? [Re: Mopargnome] #614499
02/16/10 09:26 PM
02/16/10 09:26 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
To get the matte look with a painted on stripe you'd need to have the paint flattened out a little and then spray the stripe color over top of the clear coat.
Re: Pros and Cons of painted on stripes? [Re: Neil] #614500
02/17/10 01:24 AM
02/17/10 01:24 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The stripe was painted on my sons Dart and then clear coated over. It was done in 1998 and it still looks great. Ron
Re: Pros and Cons of painted on stripes? [Re: 383man] #614501
02/17/10 02:30 AM
02/17/10 02:30 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How complicated of a stripe? I'd imaging a roadrunner strip like mine would not be worth the effort to paint on.
Re: Pros and Cons of painted on stripes? [Re: DaytonaTurbo] #614502
02/17/10 09:02 PM
02/17/10 09:02 PM
Richmond, TX
Sinister68 Offline
Sinister68  Offline
Richmond, TX
I prefer paint.
These stripes don't really show up unless there is a lot of sunlight. Kinda like 'stealth' stripes.
-James 2013 Challenger SRT 1968 Charger R/T
Re: Pros and Cons of painted on stripes? [Re: MY340] #614503
02/18/10 04:47 AM
02/18/10 04:47 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If it does not have to be factory correct for a restoration, the painted on stripes (with base/clear) is the way to go. The decals fade and discolor, and start to crack after several years. The rear R/T stripe (white) on my '69 Convertible is faded, discolored, and starting to get small cracks, while the rest if the paint still looks decent.
I painted the black stripes, and hood blackout on my '71 charger, This was a base/clear paint job, and the paint and stripes still look great, but it did take quite a bit of time to lay out the stripes using the fine-line tape. Also, with the paint in stripes, The stripes were painted further into the trunk area.
Re: Pros and Cons of painted on stripes? [Re: 451Mopar] #614504
02/18/10 11:09 AM
02/18/10 11:09 AM
Santa Fe,Texas
TexasMopar Offline
TexasMopar  Offline
Santa Fe,Texas
Stripes painted on or decals?
A matter of personal preference.
Painted on last indefinitely.
Decals fade,crack,etc.
I chose decals because I wanted to be factory correct.
Re: Pros and Cons of painted on stripes? [Re: TexasMopar] #614505
02/18/10 11:32 AM
02/18/10 11:32 AM
San Antonio, TX
San Antonio, TX
I forgot my dad painted his stripe on his 67' Dart GTS, which was much trickier because the center of the stripe is supposed to form a very, and I mean very, subtle V to be factory correct. I think we spent a day or so making proper measurements then lining up the tape.
Re: Pros and Cons of painted on stripes? [Re: TexasMopar] #614506
02/18/10 11:33 AM
02/18/10 11:33 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
If you damage the car in a wreck or garage mishap you will be glad you used decals instead of paint.
Re: Pros and Cons of painted on stripes? [Re: TexasMopar] #614507
02/18/10 11:38 AM
02/18/10 11:38 AM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
Painted stripes- Everything has to go just right with the fine-line tape and removal so you don't get bleed-through under the tape or something go wrong on removal..
Decals- Wide decals going over body contours can be a pain to get flat and get all air bubbles out..
Myself- 3 year old Pheonix-Graphics decals that still look just like they did the day I put them on, when I messed one of them up going on they sent me another one of that piece dirt cheap
Re: Pros and Cons of painted on stripes? [Re: donbarnes] #614508
02/18/10 03:18 PM
02/18/10 03:18 PM
Port Saint Lucie, FL
ChallengerGary Offline
If you are going with the factory style 1970 dual longitudinal stripes, they are pretty easy to layout and paint. As others have said, if your car is outside a lot, they with probably last longer plus it will give you a more custom look if they are painted on.
On the other hand, if you are looking to do the upper body stripes like on a 71 or 72, they are harder to get right unless you order a stencil/mask kit.
Truthfully, it boils down to personal preferences. Me, I'd prefer if you bought some stripes from me but I can see the benefit of painting them on as well. Even though I actually produce stripes myself, I sometimes paint them on based on my "vision" for the car/truck I am building.
Of course the biggest con of painting on stripes is if you change your mind and want to do something different down the road.
Re: Pros and Cons of painted on stripes? [Re: ChallengerGary] #614509
02/18/10 03:27 PM
02/18/10 03:27 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Pro's:
- last longer
- easier to clean, wax, etc.
- looks very clean
Cons's:
- not correct
- more work/more expensive to have done
- texture/gloss is incorrect
- repairs are more complicated and expensive
- painted stripes sometimes "get lost" in the reflection of light of the panel compared to traditional vinyl stripes and decals.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Pros and Cons of painted on stripes? [Re: ChallengerGary] #614510
02/18/10 03:31 PM
02/18/10 03:31 PM
Missouri
MY340 Offline OP
MY340  Offline OP
Missouri
Gary,
If I don't have them painted I'll buy from you. I'm just kinda looking for opinions right now. The side stripes will be the 71-72 style with 360 callouts.
Thanks!
