70 B BODY GLOVE BOX DOOR #614102
02/15/10 05:14 PM
02/15/10 05:14 PM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
Please help i need to remove glove box door lock on 70 ralley dash any help .The chrome lock cover has to come off some how? Thanks !!
Re: 70 B BODY GLOVE BOX DOOR [Re: HEMI ROY] #614103
02/15/10 05:38 PM
02/15/10 05:38 PM
indiana
generallee6901 Offline
indiana
I think it just pops off but am not 100% on that.
Re: 70 B BODY GLOVE BOX DOOR [Re: generallee6901] #614104
02/15/10 05:42 PM
02/15/10 05:42 PM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
thanks i thought that but that plastic is so fragile i was afraid i'd break it
Re: 70 B BODY GLOVE BOX DOOR [Re: HEMI ROY] #614105
02/15/10 05:43 PM
02/15/10 05:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
It's pure misery to remove, you sure it's gotta come off?
Re: 70 B BODY GLOVE BOX DOOR [Re: DAYCLONA] #614106
02/15/10 05:46 PM
02/15/10 05:46 PM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
i need to i'm changing interior color to 69 red color thank you any suggestions pull and pry and pray??
Re: 70 B BODY GLOVE BOX DOOR [Re: HEMI ROY] #614107
02/15/10 06:24 PM
02/15/10 06:24 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Sad to say I usually let the kid do it ....if I do it, there's a chance of
Seriously I know you need the key inserted, there's a slot or hole in the rear, kid usually sticks a paper clip in to release the front lock section from the rear while turning the key at the same time,...she's not home otherwise I ask her, I'll wrestle the things for hurs the kid has it done in 5 mins!
Mike
Re: 70 B BODY GLOVE BOX DOOR [Re: DAYCLONA] #614108
02/15/10 06:32 PM
02/15/10 06:32 PM
Iowa
70B Body Offline
70B Body  Offline
Iowa
Here's a picture of where the tab that needs to be pushed is.If I remember right key needs to be in lock and turned,with the tab pushed it should just pull apart.
1970 Satellite 383/AT
Re: 70 B BODY GLOVE BOX DOOR [Re: 70B Body] #614109
02/15/10 07:31 PM
02/15/10 07:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Our Savior, I'm going to have that pic tatoo'd on my arm for future reference,....Thanks Dan!
Re: 70 B BODY GLOVE BOX DOOR [Re: DAYCLONA] #614110
02/15/10 07:49 PM
02/15/10 07:49 PM
Iowa
70B Body Offline
70B Body  Offline
Iowa
Can't take all the credit.It's a picture I got from my savior years ago when I had the same problem.I forgot who it even was its been so long.
Just always kept the picture.Hope it works for for you.And keep the picture handy because I'm sure it will come up again.
Re: 70 B BODY GLOVE BOX DOOR [Re: 70B Body] #614111
02/15/10 08:48 PM
02/15/10 08:48 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Any way to get these out if you do not have the key that operates the lock? I have several I would like to disassemble.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 B BODY GLOVE BOX DOOR [Re: 70gtx440dana] #614112
02/15/10 09:19 PM
02/15/10 09:19 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Here's a full thread on it from the archives.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Once you get the gist of it, you can pop them right out. I found out not all latch mechanisms are interchangeable.
Ride eternal, shiny and chrome
Re: 70 B BODY GLOVE BOX DOOR [Re: DirectSubjection] #614113
02/15/10 11:36 PM
02/15/10 11:36 PM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
still cant get it im going to post pic i dont see no tab
Re: 70 B BODY GLOVE BOX DOOR [Re: HEMI ROY] #614114
02/15/10 11:38 PM
02/15/10 11:38 PM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
2nd pic
Re: 70 B BODY GLOVE BOX DOOR [Re: HEMI ROY] #614115
02/15/10 11:51 PM
02/15/10 11:51 PM
iowa
copchaser Offline
copchaser  Offline
iowa
First of all, you do not need the key in order to take the lock a part. You'll have to monkey around with the spring thing on the side, and use a small screw driver on that tab on the side, it will come right apart. Bring it to me and I'll have it apart in a couple of minutes. Untill you figure out the trick, it drive you nuts, maybe even postal. Good luck.
Re: 70 B BODY GLOVE BOX DOOR [Re: copchaser] #614116
02/15/10 11:59 PM
02/15/10 11:59 PM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
this tab your talking about i see the port just no tab do i force sm screw driver toward the chrome lock cover i see the layout on the lock cylinder on the threads page i just dont se the tab im bout 1/2 blind LOL but w/ glasses and magnifier and very good light i just dont see the tab to "push" down to release the lock cyl thanks guys for all your support on this BY THE WAY I DONT HAVE THE KEY I HAVE ONE THAT FITS IN NICE BUT WONT ROTATE IT I HAVE 3 OF THESE IM TRYING TO GET APART
Re: 70 B BODY GLOVE BOX DOOR [Re: 70B Body] #614117
02/16/10 12:26 AM
02/16/10 12:26 AM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
I CAN'T GET THE CHROME LOCK COVER VERTICAL BECAUSE I DONT HAVE THE KEYS I THINK THATS WHERE THE TAB IS HIDING BY THE PICS POSTED THE COVER IS IN VERTICAL POSITION TO THE LATCH CATCH
Re: 70 B BODY GLOVE BOX DOOR [Re: HEMI ROY] #614118
02/16/10 12:38 AM
02/16/10 12:38 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I just did mine 5 minutes ago after I rad this post, you have to turn the lock until you see the lock tab then push it down.
Re: 70 B BODY GLOVE BOX DOOR [Re: GTXKen] #614119
02/16/10 12:45 AM
02/16/10 12:45 AM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
DID YOU HAVE THE KEY IN YOURS ? I HAVE AN OLD KEY THAT FITS TUMBLERS IT WILL DISENGAGE THE LATCH BUT WILL NOT OUT IT TO LOCK POSITION THAT IT NEEDS TO BE ( I THINK) TO SSE THIS TAB LIKE I SAID I HAVE 3 NO KEYS AND NO LUCK THANK YOU DAN
Re: 70 B BODY GLOVE BOX DOOR [Re: HEMI ROY] #614120
02/16/10 12:57 AM
02/16/10 12:57 AM
GTXKen Offline
super gas
GTXKen  Offline
super gas
no keys
Re: 70 B BODY GLOVE BOX DOOR [Re: GTXKen] #614121
02/16/10 01:06 AM
02/16/10 01:06 AM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
NO KEYS !!!!
