Re: 8 3/4 a body green bearings
[Re: Dons Dart]
#613079
02/14/10 10:30 PM
02/14/10 10:30 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
Unfortunately, Green bearings don't come with instructions. They are easy to install, however. They press on in the order pictured in this thread.
[Re: Dons Dart]
#613080
02/14/10 10:32 PM
02/14/10 10:32 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I used a press to remove mine, you can go to a machine shop, a brick and motor parts store, or do a search on some of the shade tree ways to remove and install these as everyone has their own preference.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: Dons Dart]
#613083
02/15/10 12:27 PM
02/15/10 12:27 PM
Posts: 990 Norwalk, Ohio
sycboi
Norwalk, Ohio
I bought these bearings with the snap ring. I have Moser ends on my housing, and Moser axles and I could not get the axles to install until I removed the new inner seals from the housing ends. They would hit the seal and push back out a bit. The seals were for sure seated all the way in and they were the very thin bodied seals shown. Just a heads up if you are using a similar combo of parts...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
[Re: DoctorDiff]
#613085
02/15/10 03:59 PM
02/15/10 03:59 PM
sycboi
Norwalk, Ohio
I hoped that was it as well, but the ring was making contact with the seal. The seals were installed correctly, and completely seated. I don't know what is different about my set-up, but it is what it is...
-Michael
SuperBeast
[Re: Dons Dart]
#613087
02/15/10 10:35 PM
02/15/10 10:35 PM
DoctorDiff
Polson, MT
I recommend my Green bearing maxi-kit. It includes a pair of snap ring Green bearings, as well as all other gaskets and seals you may need for $85. USPS (Postal) shipping to Canada runs $40. Please E-mail me for more information doctordiff@gmail.comThanks, Cass
