Re: 8 3/4 a body green bearings [Re: Dons Dart] #613079
02/14/10 10:30 PM
02/14/10 10:30 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unfortunately, Green bearings don't come with instructions. They are easy to install, however. They press on in the order pictured in this thread.
Re: 8 3/4 a body green bearings [Re: Dons Dart] #613080
02/14/10 10:32 PM
02/14/10 10:32 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I used a press to remove mine, you can go to a machine shop, a brick and motor parts store, or do a search on some of the shade tree ways to remove and install these as everyone has their own preference.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 8 3/4 a body green bearings [Re: HealthServices] #613081
02/14/10 10:33 PM
02/14/10 10:33 PM
So Cal
So Cal
in
Re: 8 3/4 a body green bearings [Re: HealthServices] #613082
02/15/10 10:33 AM
02/15/10 10:33 AM
Canada
Dons Dart Offline OP
Canada
Looks stright forward thanks to all for the help.
Re: 8 3/4 a body green bearings [Re: Dons Dart] #613083
02/15/10 12:27 PM
02/15/10 12:27 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
I bought these bearings with the snap ring. I have Moser ends on my housing, and Moser axles and I could not get the axles to install until I removed the new inner seals from the housing ends. They would hit the seal and push back out a bit. The seals were for sure seated all the way in and they were the very thin bodied seals shown. Just a heads up if you are using a similar combo of parts...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: 8 3/4 a body green bearings [Re: sycboi] #613084
02/15/10 12:43 PM
02/15/10 12:43 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
OEM and Moser housing ends are 2.5" long. If the seals are installed all the way in, you should have at least 1/4" between the lock ring and the seal.
Air gets trapped between the inner seal and the wheel bearing O-ring. This often makes people think the axle bottoms out during installation.
Re: 8 3/4 a body green bearings [Re: DoctorDiff] #613085
02/15/10 03:59 PM
02/15/10 03:59 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
I hoped that was it as well, but the ring was making contact with the seal. The seals were installed correctly, and completely seated. I don't know what is different about my set-up, but it is what it is...
-Michael
SuperBeast
Re: 8 3/4 a body green bearings [Re: DoctorDiff] #613086
02/15/10 04:02 PM
02/15/10 04:02 PM
Canada
Canada
Ok Cass witch ones should I go for.I think I will let a rear end shop install the Axels and center section have a pro do it right the first time.Should I get the green with the snap ring or the green were the thrust buttoms have to be removed,also I need a center gasket pinon seal and the crush washer.Please email me with prices.Also is there anyway to ship through mail.Up here ups hits us with a huge brogage fee.
Re: 8 3/4 a body green bearings [Re: Dons Dart] #613087
02/15/10 10:35 PM
02/15/10 10:35 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I recommend my Green bearing maxi-kit. It includes a pair of snap ring Green bearings, as well as all other gaskets and seals you may need for $85. USPS (Postal) shipping to Canada runs $40.
Please E-mail me for more information
doctordiff@gmail.com
Thanks,
Cass
