Re: Best head for boosted applications
[Re: Dave W]
#612636
02/13/10 07:33 PM
02/13/10 07:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Wondering what small block head is better for boosted applications, W-8 or W-9 heads?
Thanks!
Either or... with a pressurized intake system it isnt all that critical due to the pressure but a W-8 will flow more than a W-9 so it would be easier with the W-8
[Re: MR_P_BODY]
#612637
02/13/10 08:38 PM
02/13/10 08:38 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I was always told you want a really good flowing exhaust port, the intake is not all that important. Matt
[Re: Dave W]
#612640
02/14/10 10:29 AM
02/14/10 10:29 AM
Posts: 1,090 north cakalaky
instigator
north cakalaky
I have read that the w9 is the lightest aluminum smallblock head made....so may be a little weak to use in very high horsepower forced induction applications......though definetly not sure on this at all.
From my own experiences with smallblock edelbrock heads, they were plenty robust to hold upwards of 25lbs of boost without lifting the heads as happens with many other 4-bolt head designs....
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: instigator]
#612641
02/14/10 10:39 AM
02/14/10 10:39 AM
MR_P_BODY
True that they are the lightest head BUT they also have 6 bolts per cyl to hold them down.... also they have a very good exhaust port which should really help in a pressurized system
[Re: Dave W]
#612642
02/14/10 11:14 AM
02/14/10 11:14 AM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
Thanks!
Will be able to tell you real soon how good the W8's work. Very small chamber on them. Will be a little tricky getting a good tuneup with alot of boost. Dave are you going smallblock again? Shoot me some picks of your car. Patrick was telling me a little about it.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
[Re: W8n2DustU]
#612643
02/14/10 11:33 AM
02/14/10 11:33 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
the W9's tend to crack in the rocker supports in all out drag racing applications.
8.30's @3400 lbs
[Re: Mike Swann]
#612644
02/14/10 02:23 PM
02/14/10 02:23 PM
Posts: 1,325 Orlando Fl
Dos Snails
Orlando Fl
I never hear this for people who use them for racing , just people repeating it.
