Re: Roadrunner hood latch
[Re: 440challenger]
#611890
02/12/10 10:45 PM
02/12/10 10:45 PM
Posts: 2,295 dark side of the moon
Dougsmopars
Then it's not a 68 lever. My 68 GTX has the lever under the upper molding. I beleive the road runner is the same. That looks like the lever on mine. Perhaps the road runner and GTX used different levers????? I'm not familar with 68 road runners all the ones i've owned were 69's.
[Re: 440challenger]
#611891
02/12/10 11:02 PM
02/12/10 11:02 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Looks like a 68 GTX release to me. A GTX unit won't work on a RR as you already know. GTX is shorter and bent different. Here's the pic I sent you a while back. This is correct for RR.
[Re: 440challenger]
#611894
02/13/10 10:04 AM
02/13/10 10:04 AM
rrunner
S.E. Florida, USA
ahh thanks makes sense. I will just mod the gtx one to work. Should be able to cut/weld in an extension. Thanks guys!
Think I would just find the correct lever. If you are gonna try to make it work and need measurements or better pics, drop me a line.
